Home » Modeling » EMF » Gen. Editor: Change Font Color
Gen. Editor: Change Font Color [message #693901] Thu, 07 July 2011 09:14 Go to next message
index.php/fa/3273/0/
Is it possible to change the Font Color of the Model-Element ("System Component", "Parameter", "Value")? The Name of the Element (such as "Aircraft") should stay black.
Thanks.
  • Attachment: labletext.jpg
    (Size: 22.28KB, Downloaded 901 times)
Re: Gen. Editor: Change Font Color [message #694027 is a reply to message #693901] Thu, 07 July 2011 12:38 Go to previous messageGo to next message
Yes, you can enable Color Providers in the GenModel and the specialize
the item providers to produce the colors you want. Read the Javadoc for
IItemColorProvider for how to control the color.
On 07/07/2011 6:14 AM, S wrote:
> Thanks.
Re: Gen. Editor: Change Font Color [message #694311 is a reply to message #694027] Fri, 08 July 2011 06:12 Go to previous messageGo to next message
Thank you Ed,
I have now enabled the Color Provider and regenerated the Code. Also i have overridden the getForeground(Object object) method in my ItemProvider. Unfortunately, it is never called.
[Updated on: Fri, 08 July 2011 06:12] by Moderator
Re: Gen. Editor: Change Font Color [message #694386 is a reply to message #694311] Fri, 08 July 2011 09:16 Go to previous messageGo to next message
You have to change your plugin.xml to add the IItemColorProvider in the supported interfaces.
It is only generated once and not changed afterwards.
Re: Gen. Editor: Change Font Color [message #694459 is a reply to message #694386] Fri, 08 July 2011 12:23 Go to previous messageGo to next message
The registration is important for registered lookup, but if the right
one is explicitly created (as in the generated editor) you won't notice
the registration missing. It is important to use
AdapterFactoryLabelProvider.ColorProvider for colors to be supported so
that's likely the cause of the problem.
Re: Gen. Editor: Change Font Color [message #695196 is a reply to message #694459] Mon, 11 July 2011 04:55 Go to previous messageGo to next message
Thank you Ed,
Thank you Sylvain,
The missing ColerProvider caused the Problem.
But for now, the hole String is colored. Is there a way to use multiple colors?
In case of "System Component Aircraft", the name of the element "System Component" should has an other color as the value "Aircraft".
Ed Merks wrote on Fri, 08 July 2011 12:23
Re: Gen. Editor: Change Font Color [message #695376 is a reply to message #695196] Mon, 11 July 2011 11:51 Go to previous messageGo to next message
Sylvain,
No, I don't believe a tree widget supports that nor do the Eclipse APIs
provide such control.
On 11/07/2011 1:55 AM, S wrote:
> Thank you Ed,
> Thank you Sylvain,
> multiple colors?
>> notice the registration missing. It is important to use
>> so that's likely the cause of the problem.
Re: Gen. Editor: Change Font Color [message #893042 is a reply to message #694459] Mon, 02 July 2012 08:17 Go to previous messageGo to next message
sorry I am reopening this thread, but I wanted to do the same thing and I'm having some trouble doing so, so I will just write in here.
I also want to use different fonts and followed the steps in here. The colors appear fine in the outline view, but not in my editors. I don't exactly understand what you, Ed, meant by "using AdapterFactoryLabelProvider.ColorProvider for colors".
That means I need a ColorProvider in my editor class, correct?
What I tried is creating a ColorProvider in the editor class and calling setForeground on it in the getContentOutlinePage() of my editor on the current viewer. That is also being called fine, but the colors again only appear in the outline.
I think that my problem is only that I don't understand how I am supposed to use the ColorProvider correctly. Maybe you could just quickly tell me how that works?
Thanks a lot!
Markus
[Updated on: Mon, 02 July 2012 08:18] by Moderator
Re: Gen. Editor: Change Font Color [message #893061 is a reply to message #893042] Mon, 02 July 2012 08:54 Go to previous messageGo to next message
Use an instance of AdapterFactoryLabelProvider.FontAndColorProvider as the label provider for you editor.
Re: Gen. Editor: Change Font Color [message #893067 is a reply to message #893061] Mon, 02 July 2012 09:07 Go to previous messageGo to next message
Thanks!
Sylvain EVEILLARD wrote on Mon, 02 July 2012 08:54
Re: Gen. Editor: Change Font Color [message #893518 is a reply to message #893067] Wed, 04 July 2012 08:32 Go to previous messageGo to next message
One more thing: is that not possible for a ListViewer for some reason? It works fine in the tree and the table viewer for me, but the ListViewer does not show the same behaviour...
Re: Gen. Editor: Change Font Color [message #893529 is a reply to message #893518] Wed, 04 July 2012 09:05 Go to previous message
<html>
<head>
<meta content="text/html; charset=UTF-8" http-equiv="Content-Type">
</head>
Markus,<br>
<br>
I see this in the Javadoc for AbstractListViewer so I'd say no, it
doesn't support that.<br>
<br>
<style type="text/css" charset="ISO-8859-1">/* Font definitions */
html { font-family: 'Segoe UI',sans-serif; font-size: 9pt; font-style: normal; font-weight: normal; }
body, h4, h5, h6, p, table, td, caption, th, ul, ol, dl, li, dd, dt { font-size: 1em; }
pre { font-family: monospace; }
h1 { font-size: 1.8em; }
h2 { font-size: 1.2em; }
h3 { font-size: 1.1em; }
/* Margins */
body { overflow: auto; margin-top: 5px; margin-bottom: 4px; margin-left: 8px; margin-right: 4px; }
h1 { margin-top: 0.3em; margin-bottom: 0.04em; }
h2 { margin-top: 2em; margin-bottom: 0.25em; }
h3 { margin-top: 1.7em; margin-bottom: 0.25em; }
h4 { margin-top: 2em; margin-bottom: 0.3em; }
h5 { margin-top: 0px; margin-bottom: 0px; }
p { margin-top: 1em; margin-bottom: 1em; }
pre { margin-left: 0.6em; }
ul { margin-top: 0px; margin-bottom: 1em; margin-left: 1em; padding-left: 1em; }
li { margin-top: 0px; margin-bottom: 0px; }
li p { margin-top: 0px; margin-bottom: 0px; }
ol { margin-top: 0px; margin-bottom: 1em; margin-left: 1em; padding-left: 1em; }
dl { margin-top: 0px; margin-bottom: 1em; }
dt { margin-top: 0px; margin-bottom: 0px; font-weight: bold; }
dd { margin-top: 0px; margin-bottom: 0px; }
/* Styles and colors */
a:link { color: #0000FF; }
a:hover { color: #000080; }
a:visited { text-decoration: underline; }
a.header:link { text-decoration: none; color: #000000 }
a.header:visited { text-decoration: none; color: #000000 }
a.header:hover { text-decoration: underline; color: #000080; }
h4 { font-style: italic; }
strong { font-weight: bold; }
em { font-style: italic; }
var { font-style: italic; }
th { font-weight: bold; }
</style><br>
<p>The list viewer implementation of this <code>Viewer</code>
framework method ensures that the given label provider is an
instance of <code>ILabelProvider</code>. <b>The optional
interfaces <code><a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.cheatsheets/D:%5C/sandbox%5C/4.2RC1%5C/eclipse%5C/plugins%5C/org.eclipse.jface_3.8.0.v20120429-1603.jar%3Corg.eclipse.jface.viewers%28AbstractListViewer.class%E2%98%83AbstractListViewer%7EsetLabelProvider%7ELorg.eclipse.jface.viewers.IBaseLabelProvider;%E2%98%82IColorProvider">IColorProvider</a></code>
and <code><a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.cheatsheets/D:%5C/sandbox%5C/4.2RC1%5C/eclipse%5C/plugins%5C/org.eclipse.jface_3.8.0.v20120429-1603.jar%3Corg.eclipse.jface.viewers%28AbstractListViewer.class%E2%98%83AbstractListViewer%7EsetLabelProvider%7ELorg.eclipse.jface.viewers.IBaseLabelProvider;%E2%98%82IFontProvider">IFontProvider</a></code>
have no effect for this type of viewer</b>
</p>
<div><b>Overrides:</b> <a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.cheatsheets/D:%5C/sandbox%5C/4.2RC1%5C/eclipse%5C/plugins%5C/org.eclipse.jface_3.8.0.v20120429-1603.jar%3Corg.eclipse.jface.viewers%28StructuredViewer.class%E2%98%83StructuredViewer%7EsetLabelProvider%7ELorg.eclipse.jface.viewers.IBaseLabelProvider;">setLabelProvider(...)</a>
in <a
href="eclipse-javadoc:%E2%98%82=org.eclipse.emf.cheatsheets/D:%5C/sandbox%5C/4.2RC1%5C/eclipse%5C/plugins%5C/org.eclipse.jface_3.8.0.v20120429-1603.jar%3Corg.eclipse.jface.viewers%28StructuredViewer.class%E2%98%83StructuredViewer">StructuredViewer</a></div>
<dl>
<dt>Parameters:
</dt>
<dd><b>labelProvider</b> the label provider, or <code>null</code>
if none</dd>
<dt><br>
</dt>
</dl>
<base
href="http://127.0.0.1:57694/help/nftopic/jar:file:/D:/sandbox/4.2RC1/eclipse/plugins/org.eclipse.platform.doc.isv_4.2.0.v20120518-2015.jar%21/reference/api/org/eclipse/jface/viewers/AbstractListViewer.html">You
could try a table with a single column and to table header.<br>
<br>
<br>
<div class="moz-cite-prefix">On 04/07/2012 2:32 PM, Markus G wrote:<br>
</div>
<blockquote cite="mid:jt1d40$h2r$1@xxxxxxxxe.org" type="cite">One
<br>
</blockquote>
<br>
<br>
</body>
</html>
Previous Topic:Genmodel Label Feature
Next Topic:Xcore how to define the value of an EnumLiterals
Current Time: Sat Sep 20 10:31:26 EDT 2025
Powered by FUDForum. Page generated in 0.03777 seconds
