Webviewer inside RCP Application not working with Indigo [message #693833] |
Thu, 07 July 2011 05:31  |
I have an Eclipse RCP application, just upgraded to Eclipse Indigo.
Now I noticed the BIRT webviewer is not working anymore.
I also found the problem out:
Due to a bugfix (https://bugs.eclipse.org/bugs/show_bug.cgi?id=336767) the method isValidFilePath returns false.
// check and aply url report path policy
if ( !POLICY_ALL.equalsIgnoreCase( urlReportPathPolicy ) )
This statement inside the method is true, because urlReportPathPolicy is null.
I use following code to run the webviewer:
Browser browser = new Browser(parent, SWT.NONE);
Bundle bundle = Activator.getDefault().getBundle();
URL url = null;
URL installURL = bundle.getEntry( "/" );
// Settings for the report viewer
HashMap<String,String> myparms = new HashMap<String,String> ();
myparms.put("SERVLET_NAME_KEY", "frameset");
myparms.put("FORMAT_KEY", "html");
try
url = new URL(installURL, "/bchistory_report_rcp.rptdesign");
catch (MalformedURLException e)
ModelEditorErrorHandler.showException(e, Activator.PLUGIN_ID);
// bugfix, see https://bugs.eclipse.org/bugs/show_bug.cgi?id=291551
browser.addOpenWindowListener(new OpenWindowListener()
public void open(WindowEvent event)
new
org.eclipse.birt.report.viewer.browsers.embedded.EmbeddedBrowser(event,
Display.getCurrent().getActiveShell());
if(new BCHistoryReport().getBCHistoryData().size() > 0)
WebViewer.display(url.toString(), browser, myparms);
I did not find a solution to set this variable from outside. Can anybody give me a hint please ?
Sincerly Patrick
[Updated on: Thu, 07 July 2011 07:00] by Moderator
Re: Webvier inside RCP Application not working with Indigo [message #695579 is a reply to message #694797] |
Tue, 12 July 2011 00:04  |
The only thing I can think of is to checkout the viewer plugin and
change the source or use code in your app to locate the report like:
Bundle bundle =
org.eclipse.core.runtime.Platform.getBundle("org.eclipse.birt.examples.yourapp");
URL url = FileLocator.find(bundle, new
Path("/reports/myreport.rptdesign"), null);
String rpt = FileLocator.toFileURL(url).getPath();
Jason
On 7/9/2011 3:22 PM, Patrick Schmitt wrote:
> I am using a URL, based on the install url of the plugin. see the
> attached source code from post #1
> Any Idea what I can do ?
FUDForum. Page generated in 0.03762 seconds
