Re: New To BIRT [message #692990 is a reply to message #692953] |
Tue, 05 July 2011 14:56 |
Rory,
You can do this by adding computed columns to the dataset or adding
columns to the table bindings. Look at the attached example that shows
both methods. Table one uses the dataset computed columns and table two
uses the new bindings for the table report item,
Jason
On 7/5/2011 10:38 AM, Rory wrote:
> Hello Everyone,
> I'm new to BIRT and my first project requires an aggregation of columns.
> If I have a data set with columns "Item Cost" "Level 1 Markup" "Level 2
> Markup" and "Level 3 Markup" how can I multiply "Item Cost" and "Level 1
> Markup" in a new column? after I do this I need to Multiply the new
> column by the "level 2 markup" in another new column. any help would be
> greatly appreciated.
> Rory St. Jean
FUDForum. Page generated in 0.03675 seconds
