Debugging JRuby in Java container with dltk [message #692553] |
Mon, 04 July 2011 18:10 |
andrew.green.df Messages: 1 Registered: July 2011 |
Junior Member |
I'm trying to get interactive debugging working on my JRuby scripts that are called from Java.
My Java code goes basically like this:
System.setProperty("jruby.debug.fullTrace", "true");
ScriptingContainer container = new ScriptingContainer(LocalContextScope.CONCURRENT);
// ... setup of load path, gem directory and other extraneous stuff omitted here
container.runScriptlet("require 'my_ruby_stuff'");
And my_ruby_stuff.rb starts out like this:
require 'rubygems'
require 'ruby-debug'
require 'ruby-debug-ide'
Debugger.wait_connection = true
Debugger.start_remote
I have also inserted a debugger line into my Ruby script a little further along, at the point where I want debugging to start.
I can run my Java app from Eclipse, and debugging seems to start correctly in the embedded Ruby script. On the Eclipse console, I get the following messages:
Fast Debugger (ruby-debug-ide 0.4.16, ruby-debug-base 0.10.3.2) listens on 127.0.0.1:8990
...and the script apparently waits where I told it to. So an IDE debugger client should be able to attach to my script, right?
To try to do this, in Eclipse debug configurations, I created a new Remote Ruby Application configuration. Initially, Eclipse didn't let me register my Java project in the "Project" field, so I added <nature>org.eclipse.dltk.ruby.core.nature</nature> to the <natures> element in my project file. After that, I could add the project to the Remote Ruby Application debug config. I set the port, and a required Ide Key.
However, when I try to connect to my script with this debug config, it doesn't work--a connection is never established.
I also tried adapting the instructions at http: //wiki.eclipse.org/DLTK_Ruby_RemoteDebugger, extracting the .rb source files from the plugin jars as suggested, and setting the mentioned environment variables as part of the run config of the calling Java app. However, including a
in my Ruby script either raises an error or changes nothing (depending on what other libraries I require first).
However, I can connect to the embedded Ruby script using the command line debugger (and not using the require 'FastRunner.rb'). If in my Ruby code I do this:
require 'rubygems'
# removed from setup: require 'ruby-debug-ide'
..then I can go into my Ruby code from the console with a simple rdebug --client -p 8989
(Strangely, the port number I have to use here is one less than the port number announced in the console message from ruby-debug-ide when I use that gem, as I mentionned above.)
Also, if I just say
require 'rubygems'
then I get the command-line Ruby debugger inside an Eclipse console (which I guess, technically speaking, is debugging inside Eclipse, but it's not quite what I want...)
Any suggestions would be greatly appreciated.
BTW, I'm using JRuby 1.6.2 (though I had to bring it down to 1.5.6 to get ruby-debug-ide to make the native extensions for that gem to compile). ruby-debug version is 0.10.4, ruby-debug-ide version is 0.4.16, Eclipse 3.6.2, dltk 3.0 (though when I tried it with the require 'FastRunner.rb', I was using 2.0). On Debian GNU/Linux testing/unstable amd_64.
Many thanks in advance,
Andrew
FUDForum. Page generated in 0.02711 seconds
