Re: Birt and Hive [message #692912 is a reply to message #692528] |
Tue, 05 July 2011 12:45 |
Wouter,
Are all the exceptions listed as warning? Does the data set still
return data?
Jason
On 7/4/2011 12:47 PM, Wouter de Bie wrote:
> I've come a little further on this. Birt connects, but I get "Method not
> supported" (see stacktrace below). I've seen this before when trying out
> different applications that do JDBC. Am I doing something completely
> wrong or should I get hive drivers from somewhere else?
> Jul 4, 2011 6:44:20 PM
> org.eclipse.birt.report.data.oda.jdbc.ui.editors.MetaDataRetriever <init>
> WARNING: Cannot retrieve the parameter metadata.
> SQL error #1:Method not supported
> org.eclipse.birt.report.data.oda.jdbc.JDBCException: Cannot retrieve the
> parameter metadata.
> java.sql.SQLException: Method not supported
> at
> org.eclipse.birt.report.data.oda.jdbc.Statement.getParameterMetaData(Statement.java:897)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.editors.MetaDataRetriever.<init>(MetaDataRetriever.java:70)
> at
> org.eclipse.birt.report.data.oda.jdbc.ui.editors.SQLDataSetEditorPage.collectDataSetDesign(SQLDataSetEditorPage.java:665)
> at
> org.eclipse.datatools.connectivity.oda.design.internal.ui.DataSetWizardPageCore.finishDataSetDesign(DataSetWizardPageCore.java:395)
> at
> org.eclipse.datatools.connectivity.oda.design.internal.ui.DataSetWizardBase.collectDataSetDesignFromPage(DataSetWizardBase.java:365)
> at
> org.eclipse.datatools.connectivity.oda.design.internal.ui.DataSetWizardBase.finishDataSetDesign(DataSetWizardBase.java:387)
> at
> org.eclipse.datatools.connectivity.oda.design.internal.ui.DataSetWizardBase.performFinish(DataSetWizardBase.java:99)
> at
> org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:827)
> at
> org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:432)
> at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
> at
> org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:240)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4125)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1457)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1480)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1465)
> at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1270)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3971)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3610)
> at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
> at org.eclipse.jface.window.Window.open(Window.java:801)
FUDForum. Page generated in 0.03157 seconds
