Home » Eclipse Projects » EclipseLink » Eclipselink.ddl-generation : drop-and-create-tables don't drop tables
Eclipselink.ddl-generation : drop-and-create-tables don't drop tables [message #691879] |
Sat, 02 July 2011 17:32 |
Xavier Messages: 3 Registered: March 2011 |
I'm trying to implement a persistence layer and get stuck without being able to understand why.
I'm using Eclipselink 2.3.0 and try to write on a MySQL DB (I got the same proble when I tried on Derby, so *I suppose the DB doesn't matter), with the Eclipselink drop-and-create-tables option in the persistence.xml.
This works once, and then produces this kind of error :
[EL Warning]: 2011-07-02 15:11:32.669--ServerSession(31248093)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.DatabaseException
Internal Exception: com.mysql.jdbc.exceptions.jdbc4.MySQLSyntaxErrorException: Table 'PROJECT' already exists
Error Code: 1050
Call: CREATE TABLE PROJECT ...
I thought it could be qomething related to cache, googled and found some things like this for example :
<shared-cache-mode>NONE</shared-cache-mode>
And some variants that I tried in my persistence.xml, but nothing worked. The tests run fine once in a while, without any apparent reason. For example, they can pass just after a minor modification of the persistence.xml, but fail if I try to run them again. And the opposite happens, too.
This kind of problem didn't happen when I used Eclipselink 1.1.0. But it happens with every Eclipselink 2.x.
Here's my persistence.xml :
<persistence version="2.0" xmlns="http;//java.sun.com/xml/ns/persistence" xmlns:xsi="http;//www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http;//java.sun.com/xml/ns/persistence http;//java.sun.com/xml/ns/persistence/persistence_2_0.xsd">
<persistence-unit name="azerty" transaction-type="RESOURCE_LOCAL">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<class>...</class>
<properties>
<property name="eclipselink.target-database" value="MYSQL" />
<property name="javax.persistence.jdbc.driver" value="com.mysql.jdbc.Driver" />
<property name="javax.persistence.jdbc.url" value="jdbc:mysql://azerty.net:3306/azerty_test" />
<property name="javax.persistence.jdbc.user" value="azerty_test" />
<property name="javax.persistence.jdbc.password" value="password" />
<property name="eclipselink.ddl-generation" value="drop-and-create-tables" />
<property name="eclipselink.ddl-generation.output-mode" value="both" />
<property name="eclipselink.logging.level" value="FINE" />
</properties>
</persistence-unit>
</persistence>
I'm ready to test every idea you may have, because I've been stuck for several hours now...
Thanks in advance.
Re: (no subject) [message #694047 is a reply to message #692451] |
Thu, 07 July 2011 17:27 |
Thanks for replying, and sorry for the late reply.
Here is the trace for the one of the tables (all of them generate the same trace).
[EL Fine]: 2011-07-07 19:11:27.165--ServerSession(27978063)--Connection(3916302)--Thread(Thread[main,5,main])--DROP TABLE PROJECT
[EL Fine]: 2011-07-07 19:11:27.166--ServerSession(27978063)--Connection(3916302)--Thread(Thread[main,5,main])--CREATE TABLE PROJECT (ID BIGINT NOT NULL, CLOSUREDATE DATETIME, OFFERSELECTIONDATE DATETIME, STATUS VARCHAR(255) NOT NULL, TENDERDATE DATETIME, PRIMARY KEY (ID))
... Some other DB actions
[EL Warning]: 2011-07-07 19:11:27.408--ServerSession(9170930)--Exception [EclipseLink-4002] (Eclipse Persistence Services - 2.3.0.v20110604-r9504): org.eclipse.persistence.exceptions.DatabaseException
Error Code: 1050
Call: CREATE TABLE PROJECT (ID BIGINT NOT NULL, CLOSUREDATE DATETIME, OFFERSELECTIONDATE DATETIME, STATUS VARCHAR(255) NOT NULL, TENDERDATE DATETIME, PRIMARY KEY (ID))
Query: DataModifyQuery(sql="CREATE TABLE PROJECT (ID BIGINT NOT NULL, CLOSUREDATE DATETIME, OFFERSELECTIONDATE DATETIME, STATUS VARCHAR(255) NOT NULL, TENDERDATE DATETIME, PRIMARY KEY (ID))")
I ended up using Eclipselink 1.2 (implementing JPA 2), which does what I want it to do. That doesn't answer the 'why', but it works.
Thanks anyway !
X
Re: (no subject) [message #694739 is a reply to message #694371] |
Sat, 09 July 2011 14:12 |
Hi Chris,
Yes, it's only a warning, but my tests still don't run.
The problem isn't that the table gets created once or twice, but that I try to insert test data (always the same from one test session to another), designed to never allow duplicate entries, and that those insertions work with eclipselink 1.2 (the tables get dropped, recreated, and data gets inserted without problem), but not with eclipselink 2.3.
Given the error messages, I thought at first that the DB didn't drop the tables, but as you say, it seems that they're dropped fine, but recreated twice. So is it possible that the test data gets inserted twice too, thus the integrity constraint violation ?
I haven't looked further lately, but I will, and try to submit runnable short tests illustrating this.
Thanks !
(no subject) [message #694755 is a reply to message #694371] |
Xavier Messages: 6 Registered: July 2009 |
Hi Chris,
Thanks !
Current Time: Fri Apr 26 15:17:51 GMT 2024
Powered by FUDForum. Page generated in 0.06085 seconds
