Re: [TENEO] Discard changes on resource [message #694761 is a reply to message #694718] |
Sat, 09 July 2011 15:48 |
Hi Waldi,
It is available in the last build which has been available for a few days, but one thing, if you have objects added to
the resource and want to undo the insert then you have to manually remove them (that's why the editing commands make
sense, they help there). The same for delete, undoing a delete means adding them back to the resource/container.
gr. Martin
On 07/09/2011 02:56 PM, forums-noreply@eclipse.org wrote:
> Hi Martin,
> The thing is: I like to use Teneo becaus I like to use EMF generated classes. I think EMF classes are wounderfull, so I
> can't use Texo. I've implement some Swing renderer with EMF functionality and it doesn't make sense to discard all the
> work.
> I'm realy happy about your feature to clear the tracklist of a resource. What do you think how long it will take
> approximately? One week, one month? one year?
> Can I have a look on a changelist to see when the feature is implemented?
> Thanks
> Waldi
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
FUDForum. Page generated in 0.03674 seconds
