Home » Archived » XML Schema Definition (XSD) » Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69770 is a reply to message #69749] |
Tue, 26 September 2006 11:28 |
Martin,
No, it must be the case that EcoreFactory.eINSTANCE ==
EcorePackage.eINSTANCE.getEFactoryInstance() so this is not a reasonable
approach. You should use the factory_override extension point to
override the factory for a package (so that the actual
XyzFactory.eINSTANCE is overridden); a given package can have at most
one override in the JVM.
I'd like to understand why EEnumLiteralImpl must be serializeable,
because this implies to me that only serializeable data types can be
supported when that isn't a general restriction for EMF because it uses
the createFromString/convertToString for that. If this is absolutely
needed to support Teneo, I'd rather do it directly in EMF so that you
wouldn't need to override the factory; I know Apache's Tuscany project
is using an override of EcoreFactory.eINSTANCE to create DataObjects,
and it would be nice if Teneo still worked for that too.
Martin Taal wrote:
> I noticed that the XSDEcoreBuilder uses the EcoreFactory.eINSTANCE to
> create eenums (and maybe also other model elements). Would it be
> possible to let it use EcorePackage.eINSTANCE.getEFactoryInstance()
> instead?
> The reason that I ask is that this makes it possible to override the
> default EcoreFactory with our own implementation (by setting the
> EcoreFactory in the EcorePackage). We require our own implementation
> to make use of our own serializable EEnumLiteral.
> Btw, is overriding EcoreFactory a valid approach in this case?
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69790 is a reply to message #69770] |
Tue, 26 September 2006 12:38 |
Hi Ed,
I was expecting that there was more to it.
We are working on using EMF in combination with JSF (Java Server Faces) and also Spring Web Flow (so
not related to Teneo, although it uses it). These frameworks/technologies store state by
java-serializing the data-objects. Java serializability is also used by a number of other frameworks
(jboss seam and jboss work flow also as I understand).
There are different cases:
> Dynamic EMF
1) The DynamicEObjectImpl
I have my own serializable dynamic eobject impl which is java.io.serializable, currently I set my
own serializableeobjectfactory in the epackage to force the use of this serializable dynamiceobject
(but this is not a correct approach?).
2) the EEnumLiteral: when reading a model directly from a xsd, xsdecorebuilder will create
EEnumLiterals, in this step I want to replace the creation of a standard EEnumLiteral by my
serializable eenumliteral. I have now done this by overriding the xsdecorebuilder and changing two
statements. But I did not feel that this was a long term sound approach.
> Generated EMF (java code)
I can make the generated java code serializable by making minor changes to the jet templates. This
is workable. Although I would prefer to just use a serializable EObject.
As we use emf outside of an eclipse environment I don't think that extension-points work.
So overall the above would be much easier if for example the EObject interface would also extend
java.io.Serializable (why not?) and some other smaller changes related to using the correct
singleton enumerate instance.
But maybe/probably I overlook many things here.
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi,
>> instead?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69813 is a reply to message #69790] |
Tue, 26 September 2006 12:52 |
Martin,
Comments below.
Martin Taal wrote:
> Hi Ed,
> Faces) and also Spring Web Flow (so not related to Teneo, although it
> by a number of other frameworks (jboss seam and jboss work flow also
> as I understand).
Yes, many frameworks rely on this. I could certainly imagine an
approach similar to what we did to support java.io.Serializeable when
implement SDO 1.0 on top of EMF. I.e., one could effectively serialize
the whole resource set. What isn't always clear is how much of the
"closure" needs to be serialized, so I'm not sure if such a brute force,
one size fits all solutions is a good thing...
> > Dynamic EMF
> java.io.serializable, currently I set my own
> serializable dynamiceobject (but this is not a correct approach?).
No, this is not generally a great idea. You should use the extension
point or use the same approach as is used to implement the extension point.
> xsdecorebuilder will create EEnumLiterals, in this step I want to
> replace the creation of a standard EEnumLiteral by my serializable
> and changing two statements. But I did not feel that this was a long
Why is EEnumLiteral so special? Is it because all the other data types
are serializeable?
> changes to the jet templates. This is workable. Although I would
Extension points only work within an OSGi environment. But the same
approach (registering a descriptor to create the factory) should be
reusable in any environment.
> interface would also extend java.io.Serializable (why not?) and some
> other smaller changes related to using the correct singleton enumerate
> instance.
I've been thinking about perhaps supporting java.io.Serializeable in
general within the implementation classes (i.e., BasicEObjectImpl,
ResourceImpl, ResourceSetImpl), but as I said, the closure issue seems
tricky and I need to be sure that whatever we do wouldn't break clients
who might have taken a different approach already.
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> reasonable approach. You should use the factory_override extension
>> point to override the factory for a package (so that the actual
>> uses the createFromString/convertToString for that. If this is
>> absolutely needed to support Teneo, I'd rather do it directly in EMF
>> so that you wouldn't need to override the factory; I know Apache's
>> Tuscany project is using an override of EcoreFactory.eINSTANCE to
>> create DataObjects, and it would be nice if Teneo still worked for
>> that too.
>> Martin Taal wrote:
>>> Hi,
>>> to create eenums (and maybe also other model elements). Would it be
>>> instead?
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69830 is a reply to message #69813] |
Tue, 26 September 2006 13:17 |
Ed,
Thanks for your reply. Comments below, marked with MT>>.
gr. Martin
Ed Merks wrote:
> Martin,
> Comments below.
> Martin Taal wrote:
>> Hi Ed,
>> as I understand).
MT>> Yes serialization can be very crude (in the end you can serialize the whole jvm heap). But I
think that the one who uses java serialization is responsible for determining what is a correct set
of data to serialize (by removing references to what not should be serialized). At least that is
what the designers of java.io.Serialization thought probably.
So (imho) EMF should just support basic java.io.serialization and leave the other part of the
problem to the java developer. This is in way different from xml-serialization where EMF offers more
control (and therefor has more responsibility I think).
>> > Dynamic EMF
> are serializeable?
MT>> Yes the other base datatypes are serializable and enumliteral is not.
>> instance.
MT>> Why not just leave the closure problem to the user of EMF?
For me xml serialization and java serialization have different purposes and do not require EMF to
offer the same level of control (through resources, containment etc.).
>> gr. Martin
>> Ed Merks wrote:
>>> Martin,
>>> that too.
>>> Martin Taal wrote:
>>>> Hi,
>>>> instead?
The Netherlands
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69850 is a reply to message #69830] |
Tue, 26 September 2006 13:40 |
Martin,
So far I've only considered writePlace in combination with EMF
serialization (because this eliminates dependencies on specific
implementation classes). I think you're suggesting that just making the
object serializeable and letting Java handle it the normal way is fine;
I've never tried that and didn't think it would work. (E.g., we don't
make transient features transient in the Java sense.) We can have an
in-depth conversation about this at the Eclipse Summit in a few weeks.
;-) I'm certainly willing to consider adding support for
java.io.Serializeable directly to EEnumLiteralImpl in EMF if that makes
folks happy and isn't likely to cause anyone problems. In fact, I'd
suggested someone open a feature request for generating serializeable
type safe enums, which they didn't follow up on; perhaps it doesn't make
sense to do that given that we should be able to generate Java 5.0 enums
in the next release cycle...
Martin Taal wrote:
> Ed,
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> Comments below.
>> Martin Taal wrote:
>>> Hi Ed,
>>> as I understand).
>> serialize the whole resource set. What isn't always clear is how
>> much of the "closure" needs to be serialized, so I'm not sure if such
>> a brute force, one size fits all solutions is a good thing...
> the whole jvm heap). But I think that the one who uses java
> serialization is responsible for determining what is a correct set of
> serialized). At least that is what the designers of
> leave the other part of the problem to the java developer. This is in
> way different from xml-serialization where EMF offers more control
>>> > Dynamic EMF
>> point.
>> types are serializeable?
> not.
>>> enumerate instance.
>> seems tricky and I need to be sure that whatever we do wouldn't break
>> clients who might have taken a different approach already
> purposes and do not require EMF to offer the same level of control
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Martin,
>>>> most one override in the JVM.
>>>> be supported when that isn't a general restriction for EMF because
>>>> it uses the createFromString/convertToString for that. If this is
>>>> EMF so that you wouldn't need to override the factory; I know
>>>> Apache's Tuscany project is using an override of
>>>> EcoreFactory.eINSTANCE to create DataObjects, and it would be nice
>>>> Martin Taal wrote:
>>>>> Hi,
>>>>> be possible to let it use
>>>>> EcorePackage.eINSTANCE.getEFactoryInstance() instead?
>>>>> the default EcoreFactory with our own implementation (by setting
>>>>> the EcoreFactory in the EcorePackage). We require our own
>>>>> implementation to make use of our own serializable EEnumLiteral.
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69870 is a reply to message #69850] |
Wed, 27 September 2006 07:07 |
Hi Ed,
Okay, I am looking forward to an in-depth discussion on java.io.serialization and EMF ;-).
When will there be java 5 support in EMF, or when is the next release cycle planned?
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Ed,
>> gr. Martin
>> Ed Merks wrote:
>>> Martin,
>>> Comments below.
>>> Martin Taal wrote:
>>>> Hi Ed,
>>>> as I understand).
>>>> > Dynamic EMF
>>> point.
>> not.
>>>> enumerate instance.
>>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Martin,
>>>>> Martin Taal wrote:
>>>>>> Hi,
The Netherlands
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #69893 is a reply to message #69870] |
Wed, 27 September 2006 11:28 |
Martin,
Our latest coop student is working on AST-based JMerge, which we need to
support Java 5.0 syntax in the generator, while the rest of us
developers (Marcelo, Dave and I) are still working on completing the
second edition of the book. With EMF 2.2.1 development completed today,
we (especially me, because I don't like working on the book!) will
likely start our 3.0 development stream in the next week or two and the
cycle completes on Eclipse's regular yearly cycle that ends each June.
Martin Taal wrote:
> Hi Ed,
> cycle planned?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> the object serializeable and letting Java handle it the normal way is
>> fine; I've never tried that and didn't think it would work. (E.g., we
>> don't make transient features transient in the Java sense.) We can
>> have an in-depth conversation about this at the Eclipse Summit in a
>> few weeks. ;-) I'm certainly willing to consider adding support for
>> makes folks happy and isn't likely to cause anyone problems. In
>> fact, I'd suggested someone open a feature request for generating
>> serializeable type safe enums, which they didn't follow up on;
>> perhaps it doesn't make sense to do that given that we should be able
>> to generate Java 5.0 enums in the next release cycle...
>> Martin Taal wrote:
>>> Ed,
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Martin,
>>>> Comments below.
>>>> Martin Taal wrote:
>>>>> Hi Ed,
>>>>> used by a number of other frameworks (jboss seam and jboss work
>>>> when implement SDO 1.0 on top of EMF. I.e., one could effectively
>>>> such a brute force, one size fits all solutions is a good thing...
>>> serialize the whole jvm heap). But I think that the one who uses
>>> set of data to serialize (by removing references to what not should
>>> be serialized). At least that is what the designers of
>>>>> > Dynamic EMF
>>>>> this serializable dynamiceobject (but this is not a correct
>>>>> approach?).
>>>> extension point or use the same approach as is used to implement
>>>>> xsdecorebuilder and changing two statements. But I did not feel
>>> is not.
>>>> same approach (registering a descriptor to create the factory)
>>>> should be reusable in any environment.
>>>>> EObject interface would also extend java.io.Serializable (why
>>>> in general within the implementation classes (i.e.,
>>>> BasicEObjectImpl, ResourceImpl, ResourceSetImpl), but as I said,
>>>> the closure issue seems tricky and I need to be sure that whatever
>>>> we do wouldn't break clients who might have taken a different
>>>> approach already
>>>>> gr. Martin
>>>>> Ed Merks wrote:
>>>>>> Martin,
>>>>>> extension point to override the factory for a package (so that
>>>>>> the actual XyzFactory.eINSTANCE is overridden); a given package
>>>>>> can have at most one override in the JVM.
>>>>>> serializeable, because this implies to me that only serializeable
>>>>>> data types can be supported when that isn't a general restriction
>>>>>> for EMF because it uses the createFromString/convertToString for
>>>>>> that. If this is absolutely needed to support Teneo, I'd rather
>>>>>> do it directly in EMF so that you wouldn't need to override the
>>>>>> factory; I know Apache's Tuscany project is using an override of
>>>>>> Martin Taal wrote:
>>>>>>> Hi,
>>>>>>> EcoreFactory.eINSTANCE to create eenums (and maybe also other
>>>>>>> model elements). Would it be possible to let it use
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598762 is a reply to message #69749] |
Ed Merks Messages: 33142 Registered: July 2009 |
Martin,
Martin Taal wrote:
> instead?
Ed Merks
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598771 is a reply to message #69770] |
Hi Ed,
> Dynamic EMF
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Hi,
>> instead?
The Netherlands
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598779 is a reply to message #69790] |
Martin,
Comments below.
Martin Taal wrote:
> Hi Ed,
> as I understand).
> > Dynamic EMF
are serializeable?
> instance.
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> that too.
>> Martin Taal wrote:
>>> Hi,
>>> instead?
Ed Merks
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598783 is a reply to message #69813] |
Ed,
gr. Martin
Ed Merks wrote:
> Martin,
> Comments below.
> Martin Taal wrote:
>> Hi Ed,
>> as I understand).
>> > Dynamic EMF
> are serializeable?
>> instance.
>> gr. Martin
>> Ed Merks wrote:
>>> Martin,
>>> that too.
>>> Martin Taal wrote:
>>>> Hi,
>>>> instead?
The Netherlands
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598792 is a reply to message #69830] |
Martin,
Martin Taal wrote:
> Ed,
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> Comments below.
>> Martin Taal wrote:
>>> Hi Ed,
>>> as I understand).
>>> > Dynamic EMF
>> point.
> not.
>>> enumerate instance.
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Martin,
>>>> Martin Taal wrote:
>>>>> Hi,
Ed Merks
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598796 is a reply to message #69850] |
Hi Ed,
gr. Martin
Ed Merks wrote:
> Martin,
> Martin Taal wrote:
>> Ed,
>> gr. Martin
>> Ed Merks wrote:
>>> Martin,
>>> Comments below.
>>> Martin Taal wrote:
>>>> Hi Ed,
>>>> as I understand).
>>>> > Dynamic EMF
>>> point.
>> not.
>>>> enumerate instance.
>>>> gr. Martin
>>>> Ed Merks wrote:
>>>>> Martin,
>>>>> Martin Taal wrote:
>>>>>> Hi,
The Netherlands
Re: Feature request: can XSDEcoreBuilder use EcorePackage.eINSTANCE.getEFactoryInstance() instead of [message #598803 is a reply to message #69870] |
Martin,
Martin Taal wrote:
> Hi Ed,
> cycle planned?
> gr. Martin
> Ed Merks wrote:
>> Martin,
>> Martin Taal wrote:
>>> Ed,
>>> gr. Martin
>>> Ed Merks wrote:
>>>> Martin,
>>>> Comments below.
>>>> Martin Taal wrote:
>>>>> Hi Ed,
>>>>> > Dynamic EMF
>>>>> approach?).
>>> is not.
>>>> approach already
>>>>> gr. Martin
>>>>> Ed Merks wrote:
>>>>>> Martin,
>>>>>> Martin Taal wrote:
>>>>>>> Hi,
Ed Merks
Current Time: Fri Apr 26 21:42:15 GMT 2024
Powered by FUDForum. Page generated in 0.04579 seconds
