Home » Eclipse Projects » EGit / JGit » Old EGit versions
Old EGit versions [message #691584] Fri, 01 July 2011 15:18 Go to next message
Is there a site where I can still access a .11 or .12 release of EGit?
We are using Indigo and EGit 1.0 for our main development, but that is giving us problems with Buckminster. So I want to setup a Helios environment solely for working on build and provisioning scripts. But whenever I try to add EGit through either the main update site or the marketplace, all that is available is 1.0, which is incompatible with the older version of Buckminster.
Even the main egit/updates aggregated site is only aggregating the 1.0 release site, and I can't find any references to the older site.
Re: Old EGit versions [message #691869 is a reply to message #691584] Sat, 02 July 2011 12:47 Go to previous messageGo to next message
You should be able to find old releases under this pattern...
http://download.eclipse.org/egit/updates-0.12
http://download.eclipse.org/egit/updates-0.11
etc...
Is there a bug open for your problem? It's unfortunate you can't use 1.0 since it's the latest and greatest.
We are planning to release 1.1 in late September...
Re: Old EGit versions [message #691940 is a reply to message #691869] Sat, 02 July 2011 17:52 Go to previous messageGo to next message
Thanks for the links. I'll search through Bugzilla to see if there is already a bug for the Buckminster problem, and if not will open one. I'm pretty sure this is all on the Buckminster side, not EGit.
Re: Old EGit versions [message #691951 is a reply to message #691940] Sat, 02 July 2011 18:57 Go to previous message
All old releases and their p2 repositories are listed here http://wiki.eclipse.org/EGit/FAQ#Where_can_I_find_older_releases_of_EGit.3F
Previous Topic:New commit dialog
Next Topic:[JGIT] How to get started
Current Time: Sat Nov 08 05:59:34 EST 2025
Powered by FUDForum. Page generated in 0.03541 seconds
