Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [TEXO] Java errors in generated code
Re: [TEXO] Java errors in generated code [message #691551 is a reply to message #691432] |
Fri, 01 July 2011 17:41 |
Mike Cooper Messages: 60 Registered: February 2011 |
Member |
Hi Martin,
You're behind Texo too? You are a very, very busy guy.
Tried to update in eclipse but got update errors:
An error occurred while collecting items to be installed
session context was:(profile=epp.package.jee, phase=org.eclipse.equinox.internal.p2.engine.phases.Collect, operand=, action=).
Artifact not found: osgi.bundle,org.eclipse.emf.texo,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo_0.1.0.v201107011214.jar
Problems downloading artifact: osgi.bundle,org.eclipse.emf.texo.generator,0.1.0.v201107011214.
MD5 hash is not as expected. Expected: 0d7a841b3fac2cb1ddc1cd5d4cea33f9 and found a6db9e2b43501d0c9187740e37cd69bf.
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator.edit,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator.edit_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator.edit.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator.edit.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.modelgenerator.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.modelgenerator.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm.edit,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm.edit_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm.edit.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm.edit.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.orm.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.orm.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.source_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.xml,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.xml_0.1.0.v201107011214.jar
Artifact not found: osgi.bundle,org.eclipse.emf.texo.xml.source,0.1.0.v201107011214.
http://download.eclipse.org/modeling/emft/texo/updates/interim/plugins/org.eclipse.emf.texo.xml.source_0.1.0.v201107011214.jar
Re: [TEXO] Java errors in generated code [message #691581 is a reply to message #691551] |
Fri, 01 July 2011 18:59 |
Indeed quite busy :-)...
I get the same error, I tried a new build but something fails on the eclipse.org hudson build infrastructure. I will try
again later and send a reply to this thread again.
gr. Martin
On 07/01/2011 07:41 PM, Mike Cooper wrote:
> Hi Martin,
> You're behind Texo too? You are a very, very busy guy. :)
> action=).
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Current Time: Fri Apr 26 02:36:39 GMT 2024
Powered by FUDForum. Page generated in 0.03788 seconds
