Home » Eclipse Projects » Web Tools incubator » [JAX-WS] Encoding(Request is sent without encoding )
icon5.gif  [JAX-WS] Encoding [message #689808] Tue, 28 June 2011 07:58 Go to next message
Hi all,
I am engaged in a small project to create a jax-ws client for several authenticated .NET web services. I have used wsimport to create all the web service objects and created the client stub and for various reasons added a SOAP handler to the web service interface. All is well except for one thing - encoding.
The SOAP message I am creating contains the correct encoding. I am setting the following within the handler:
soapMsg.getMimeHeaders().addHeader("Content-type", "text/xml; charset=utf-8");
soapMsg.setProperty(SOAPMessage.CHARACTER_SET_ENCODING, "utf-8");
and upon
soapMsg.saveChanges();
soapMsg.writeTo(System.out);
within the handler the XML is correct:
However the request being sent through the port has the encoding part removed making the request unreadable by the .NET web services:
<?xml version="1.0"?>
The Eclipse work space text-file-encoding is also set to "UTF-8".
Anyone ever met such an issue and may suggest a possible fix?
Thank you,
Trevor Grech
Re: [JAX-WS] Encoding [message #703182 is a reply to message #689808] Wed, 27 July 2011 05:08 Go to previous message
Hi all,
I still cannot figure out why the encoding is stripped out of the XML declaration when sending the request at lower levels. However I did find a work around by extending the XMLOutputFactory to force the full XML declaration.
Trevor
Previous Topic:Increase Eclipse heap size
Next Topic:Relax-NG: Status?
Current Time: Sat Nov 01 14:41:23 EDT 2025
Powered by FUDForum. Page generated in 0.27761 seconds
