Re: [Acceleo] PDE and EMTL [message #689901 is a reply to message #689649] |
Tue, 28 June 2011 15:05 |
Hi Brice,
It seems that a regression has appeared in the generation of the build.properties file.
Quote:it seems that the previous (normal?) behavior can be obtained by setting an output folder equals to the source folder (outputFolder="${target.folder}") in the task defined in the "build.acceleo" file. However, I am not sure this is one of the best practices.
Even without the "outputFolder="${target.folder}" it should work but I've looked at the code and a regression has appear. You can indeed restore the previous behavior by adding "outputFolder="${target.folder}". Thanks for reporting this issue, I've fixed it. The fix will be available when Acceleo 3.1.1 will be released.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
FUDForum. Page generated in 0.02813 seconds
