Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Customize an Eclipse View with SWT
icon5.gif  Customize an Eclipse View with SWT [message #688209] Fri, 24 June 2011 03:20 Go to next message
Hello!
I have developed a plugin, a new Eclipse view (ViewPart).
And I would like to use SWT tools to modify my view (Sash, ScrolledComposite...).
I am displaying a TreeViewer and I use a contentprovider and a labelprovider.
public void createPartControl(Composite parent) {
		treeviewer = new TreeViewer(parent, SWT.H_SCROLL | SWT.V_SCROLL);
		treeviewer.setContentProvider(new TreeContentProvider());
		treeviewer.setLabelProvider(new TreeLabelProvider());
Actually, I see an SWT program, I see an Eclipse plugin to create a new view, but I don't know how to use swt in the plugin structure.
In fact, I just want to display my tree in the upper part of my view (delimited by a sash)...
Thank you very much for your help!
Re: Customize an Eclipse View with SWT [message #690828 is a reply to message #688209] Thu, 30 June 2011 05:20 Go to previous messageGo to next message
Originally posted by: robert julian chandradoss
On 6/24/2011 12:50 PM, Renaud C wrote:
> Hello!
> labelprovider.
Renaud,
Please post some actual code to run. Also, elaborate what you
are trying to achieve, may be with figure/picture.
best regards. --julian
Re: Customize an Eclipse View with SWT [message #690978 is a reply to message #690828] Thu, 30 June 2011 09:52 Go to previous message
For now, I display 2 treeviewer separated by a Sash :
		new Sash(parent, SWT.VERTICAL);
		treeviewerTwo = new TreeViewer(parent, SWT.H_SCROLL | SWT.V_SCROLL);
		treeviewerTwo.setContentProvider(new TreeContentProviderTwo());
		treeviewerTwo.setLabelProvider(new TreeLabelProvider());
		createActions();
		createToolbar();
		getSite().setSelectionProvider(treeviewer);
		getSite().getWorkbenchWindow().getSelectionService()
				.addSelectionListener(listener);
http://www.habile-webdesign.com/plugin_screenshot.png
And now I would like to split this view horizontally, these two treeviewers on the top, and a new part below where I would like to insert another tree (result of operations between the two previous treeviewers).
And, by the way,
allows me to display properties of a treeviewer element selected. But I can use only one provider with this system, and I would like the same for the two treeviewers. Allowing to see properties of treeviewer elements and treeviewerTwo elements.
With my current code, I can see only properties of treeviewer elements.
Thanks everybody!
[Updated on: Thu, 30 June 2011 09:53] by Moderator
Previous Topic:Coolbar Mouse Listener
Next Topic:How to initiate an inactive view in an IFolderLayout
Current Time: Sun Sep 14 22:03:31 EDT 2025
Powered by FUDForum. Page generated in 0.04061 seconds
