(no subject) [message #689466 is a reply to message #689436] |
Mon, 27 June 2011 17:02 |
Ed Willink Messages: 7655 Registered: July 2009 |
Perhaps after Juno, when EMF Query and Xtext requirements are
established, it may be possible to merge the two competing solutions,
since the costs of duplicate indexing are imposed on all modeling users
that even indirectly exploit these two tools.
Ed Willink
On 27/06/2011 18:23, Ed Merks wrote:
> Saurav,
> Cool. That's a good idea.
> On 27/06/2011 3:13 AM, saurav wrote:
>> Hi Ed,
>> Well, having a common index and hence avoidance of duplicatie
>> indexing would have helped.Right now we can have a separate adapter
>> (query storage processor) for Xtext if required and let that
>> processor decide which index to use.
>> Cheers,
>> Saurav
(no subject) [message #689514 is a reply to message #689466] |
Mon, 27 June 2011 18:43 |
Ed Merks Messages: 33141 Registered: July 2009 |
Ed,
It's possible, but as I understand it, no one is particularly motivated
to do it.
On 27/06/2011 10:02 AM, Ed Willink wrote:
> Hi
> users that even indirectly exploit these two tools.
> Regards
> Ed Willink
>> Saurav,
>>> Hi Ed,
>>> Cheers,
>>> Saurav
Ed Merks
Re: (no subject) [message #689534 is a reply to message #689514] |
Mon, 27 June 2011 19:27 |
Roshan S. Messages: 125 Registered: July 2009 |
Saurav,
Does Query2 work with Eclipse 3.5? I saw your presentation on http://www.slideshare.net/sauravsarkar/query2-eclipse-day and after installing Query2 I'm not able to get some of the preferences and the query tools as you have in your presentation. I also can't install the query2 examples.
Roshan
UPDATE-So I did end up moving to 3.6.2 and I was now able to see the preferences for Query2 and Index View, Query View, etc. However, when updating through the update site for Query2 I get an error when I try to add EMF Query2 Tests and Examples. I'm missing the library swtbot:
Cannot complete the install because one or more required items could not be found.
Software being installed: Query2 Tests 1.0.0.201105300149 (org.eclipse.emf.query2.test.feature.feature.group 1.0.0.201105300149)
Missing requirement: org.eclipse.emf.query2.index.ui.test 1.0.0.201105300149 requires 'bundle org.eclipse.swtbot.eclipse.core 2.0.4' but it could not be found
Cannot satisfy dependency:
From: Query2 Tests 1.0.0.201105300149 (org.eclipse.emf.query2.test.feature.feature.group 1.0.0.201105300149)
To: org.eclipse.emf.query2.index.ui.test [1.0.0.201105300149]
Once I added the update site for SWTBOT http://download.eclipse.org/technology/swtbot/helios/dev-build/update-site I was good to go.
[Updated on: Mon, 27 June 2011 22:29] Report message to a moderator
Re: (no subject) [message #690301 is a reply to message #690035] |
Wed, 29 June 2011 10:30 |
saurav sarkar Messages: 428 Registered: July 2009 |
Hi Roshan,
If you are using the builder then you must have to add your project the index nature.You can add it by right click on the context menu of the project and click on 'Add/Remove Index Nature'.
And yes if you are trying to index any other files apart from xmi you need to add it in the ExtensionToFactory map.
Please open a new thread relating to Query2 in the EMF sub-forum if you have further questions because this thread has already been long enough
and has some generic discussions.
cheers,
Saurav
My Blog http://codifyit.blogspot.com/
Follow me: http://twitter.com/sauravs
FUDForum. Page generated in 0.03629 seconds
