Home » Modeling » MoDisco » Modisco installation
Modisco installation [message #687908] Thu, 23 June 2011 09:53 Go to next message
Hi...
I am trying to install modisco on eclipse 3.6 for hours and hours... and the nervous breakdown is closer and closer...
I had to give up the 0.9 version, since it requires com.ibm.icu.4.4.2... (Is it a really mandatory required dependency, or would it be possible to relax the constraint ?)
So I tried the 0.8.2, but there is always something missing or incompatible...
Did someone succeed in installing Modisco on a 3.6 eclipse ?
If yes, how ?
Re: Modisco installation [message #687965 is a reply to message #687908] Thu, 23 June 2011 11:22 Go to previous messageGo to next message
Hi Romain,
the fact is that MoDisco 0.9.0 has Eclipse 3.7 prerequisites.
0.8.2 works with Eclipse 3.6. But the update install may fail depending on other Eclipse components already installed in your Eclipse. What are the messages errors when you try from update site ?
A simple way to have MoDisco (0.8.2 or 0.9.0) is :
- download Eclipse Moddeling bundle (3.6.2 or 3.7.0)
- start it and open "Install Modeling Components" from the toolbar
- select MoDisco in the components
Find a complete install page : http://wiki.eclipse.org/MoDisco/Installation
Fabien Giquel.
Re: Modisco installation [message #694309 is a reply to message #687965] Fri, 08 July 2011 06:08 Go to previous messageGo to next message
I finally succeeded in installing the 0.9 version on a fresh 3.7 eclipse version... but still failed on the 3.6...
Anyway, thank you for your answer...
I have now problems with discovering the commons-math last version (using last sources from the svn repository):
- a "java.lang.ClassCastException: org.eclipse.gmt.modisco.java.emf.impl.AnnotationTypeMemberDeclarationImpl cannot be cast to org.eclipse.gmt.modisco.java.AbstractMethodDeclaration"
- and a "java.lang.NullPointerException at org.eclipse.modisco.java.discoverer.internal.io.java.MethodRedefinitionManager.getRawSignature(MethodRedefinitionManager.java:108)" that terminates the discovery process...
I checked the option "LOG_JAVA_ANALYSIS_WARNINGS", but no log file is generated...
Is there another way to find out on which place the NullPointerException occurs (some kind of debug option ?) ?
Thanks for your help,
Re: Modisco installation [message #694433 is a reply to message #694309] Fri, 08 July 2011 11:16 Go to previous message
Hi Romain,
I could reproduce the issue you describe.
I've filed a bug : https://bugs.eclipse.org/bugs/show_bug.cgi?id=351590
We will investigate this problem.
You can see the stacktrace by double-clicking on the error message in the Error Log view in Eclipse, or in "<workspace>/.metadata/.log"
[Updated on: Fri, 08 July 2011 11:29] by Moderator
Previous Topic:Infinite (?) execution when trying to discover KDM code model from ADempiere
Next Topic:Query Manager
Current Time: Mon Jun 16 16:06:52 EDT 2025
Powered by FUDForum. Page generated in 0.04440 seconds
