Home » Modeling » GMF (Graphical Modeling Framework) » Exception while generation diagram code
Exception while generation diagram code [message #687642] |
Wed, 22 June 2011 22:29 |
Borislav Messages: 3 Registered: June 2011 |
I have a problem using GMF on Eclipse Indigo. I use the plugins as described here: gmp/development/releases.php
I made a UI model project and i am trying to create the diagram editor for it. The problem is that the following exception occurs and the generated code has missing dependancies.
Problems while generating code
Exception (Can't evaluate LET expression: actual variable type is not assignable to declared one:in xpt::navigator::NavigatorContentProvider, line 491) while generating code
Exception (Can't evaluate LET expression: actual variable type is not assignable to declared one:in xpt::navigator::NavigatorContentProvider, line 506) while generating code
Exception (Boolean expected (was: org.eclipse.emf.ecore.impl.DynamicEObjectImpl)!:in xpt::diagram::commands::CreateNodeCommand, line 104) while generating code
Exception (Can't evaluate LET expression: actual variable type is not assignable to declared one:in impl::diagram::editparts::NodeEditPart, line 356) while generating code
Exception (Can't evaluate LET expression: actual variable type is not assignable to declared one:in xpt::navigator::NavigatorContentProvider, line 228) while generating code
My question is if somebody can help me solve this issue?
[Updated on: Wed, 22 June 2011 22:34] Report message to a moderator
Re: Exception while generation diagram code [message #688305 is a reply to message #687642] |
Fri, 24 June 2011 11:39 |
Hugo A. Garcia Messages: 258 Registered: July 2009 |
I also have this problem and I found that it got fixed:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=346952
but the update with the fix is not available from the update site. I've
tried getting the source from cvs but I am unable to resolve some of the
dependencies to some Orbit packages.
In short... seem anybody trying to use GMF Tooling with Indigo is stuck
at the moment until some interim release is available.
-H
Re: Exception while generation diagram code [message #688337 is a reply to message #688305] |
Fri, 24 June 2011 13:13 |
It is currently not possible to use GMF Tooling on Indigo.
There is still a critical but to fix before releasing GMF Tooling
https://bugs.eclipse.org/bugs/show_bug.cgi?id=349941
Once this one is fixed, there will be a release candidate that you (the
GMF Tooling users community) will be invited to test for your diagrams.
If no critical bug is met, GMF Tooling will hopefully be released at the
beginning of July.
On 24/06/2011 13:39, Hugo A. Garcia wrote:
> Hi
> -H
>> code
>> code
>> code
>> code
Re: Exception while generation diagram code [message #688339 is a reply to message #688305] |
beginning of July.
> Hi
> -H
>> code
>> code
>> code
>> code
Current Time: Fri Apr 26 07:29:13 GMT 2024
Powered by FUDForum. Page generated in 0.03651 seconds
