Re: Choice within a sequence [message #68970 is a reply to message #68927] |
Wed, 26 July 2006 17:21 |
--------------070401030901040001060606
Stuart,
If, after this line in
XSDPrototypicalSchema.initializeSimpleRecursiveModelGroupDef inition,
// Add the wildcard particle to the model group.
modelGroup.getContents().add(wildcardParticle);
I add the following:
XSDParticle choiceParticle = xsdFactory.createXSDParticle();
XSDModelGroup choiceGroup = xsdFactory.createXSDModelGroup();
choiceGroup.setCompositor(XSDCompositor.CHOICE_LITERAL);
choiceParticle.setContent(choiceGroup);
modelGroup.getContents().add(choiceParticle);
this result is produced:
<xsd:group name="simpleRecursiveModelGroupDefinition">
<xsd:annotation/>
<xsd:sequence>
<xsd:element maxOccurs="unbounded" minOccurs="0"
ref="PTS:simpleRecursiveElementDeclaration"/>
<xsd:any namespace="##other" processContents="lax"/>
<xsd:choice/>
</xsd:sequence>
</xsd:group>
Stuart Stephen wrote:
> I am trying to work out how I can use emf xsd to create the following
> snippet of XML. I just cannot work it out at the moment.
> <xs:element name="itemName">
> <xs:complexType>
> <xs:sequence>
> <xs:element name="ref"/>
> <xs:choice>
> <xs:element name="a"/>
> <xs:element name="b"/>
> </xs:choice>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> Everything is fine until I try to create choice part. How can I add a
> choice to the sequence using the Java API?
> Stuart
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Stuart,<br>
<br>
XSDPrototypicalSchema.initializeSimpleRecursiveModelGroupDef inition, <br>
<blockquote>
Re: Choice within a sequence [message #68991 is a reply to message #68949] |
Wed, 26 July 2006 17:37 |
Stuart,
This discussion was related to mapping XML Schema to Ecore. The XSD
model has always supported being able to produce any syntactically valid
XML Schema instance.
> I see that "choice within a sequence" should have been supported in
> EMF 2.0.
> http://www.codegeneration.net/tiki-read_article.php?articleI d=38
> The immortal words of Dave Steinberg were:
> "Work on EMF 2.0 is progressing, and we should start making builds
> available in the near future. The biggest improvement will be in the
> Ecore representation of models described using XML Schema, which will
> be able to represent mixed content and more complex model groups, like
> a choice within a sequence. The goal is to fully support all features
> of XML Schema."
> I am assuming that since I am now using EMF 2.2.0 this should be
> available to me?
> I would be very thankful for any help on this matter.
> Stuart
Re: Choice within a sequence [message #69116 is a reply to message #69073] |
Thu, 27 July 2006 10:53 |
Stuart,
Please open a bugzilla and I'll make that change.
> In XSDSchemaBuildingTools.addModelGroupDefinition(..) I have put the
> code:
> else if(component instanceof XSDModelGroup)
> XSDParticle particle = xsdFactory.createXSDParticle();
> particle.setContent(modelGroup);
> ((XSDModelGroup)component).getContents().add(particle);
> This works fine. Perhaps I could suggest it as a change to
> XSDSchemaBuildingTools.java.
> Stuart
Re: Choice within a sequence [message #598473 is a reply to message #68927] |
Ed Merks Messages: 33142 Registered: July 2009 |
Stuart,
<xsd:annotation/>
<xsd:sequence>
<xsd:choice/>
</xsd:sequence>
</xsd:group>
> <xs:complexType>
> <xs:sequence>
> <xs:choice>
> </xs:choice>
> </xs:sequence>
> </xs:complexType>
> </xs:element>
> Stuart
<html>
<head>
<title></title>
</head>
Stuart,<br>
<br>
<blockquote>
Ed Merks
Re: Choice within a sequence [message #598480 is a reply to message #68949] |
Stuart,
> EMF 2.0.
> of XML Schema."
> available to me?
> Stuart
Ed Merks
Re: Choice within a sequence [message #598517 is a reply to message #69073] |
Stuart,
> code:
> Stuart
Ed Merks
FUDForum. Page generated in 0.04139 seconds
