Re: [CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource [message #687222 is a reply to message #687213] |
Thu, 16 June 2011 18:45 |
Hi Goetz,
I have encountered this error also, but now it does not occur with me. It is this bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=345816
I committed a change for this bugzilla on the 15th of may, but I can't imagine that your version is older (if it is
rc4). Can you check the build date of the cdo.server.hibernate plugin (it is reflected in the version qualifier of the
plugin)?
gr. Martin
On 06/16/2011 06:24 PM, Goetz Botterweck wrote:
> SHORT STORY
> When starting CDO Hibernate Server I get
> "Not able to update container columns of CDOResource with id
> OID:http://www.eclipse.org/emf/CDO/Eresource/4.0.0#CDOResource#1"
> LONG STORY
> I want to get started with a current installation of CDO Hibernate Store.
> I installed Eclipse 3.7RC4
> + Hibernate 3.6.0
> + CDO Model Repository SDK 4.0.0
> + EMF Teneo CDO SDK 1.2.0
> + CDO Model Repository Server Hibernate 4.0.0
> + some other plugins
> (Mostly following instructions at
> http://wiki.eclipse.org/CDO/Hibernate_Store/Quick_Start)
> I then checked out example projects from
> http://dev.eclipse.org/svnroot/modeling/org.eclipse.emf.cdo/trunk/plugins/org.eclipse.emf.cdo.examples.*
> I added
> org.hsqldb;bundle-version="1.8.1"
> to the MANIFEST.MF to get around a class not found error.
> Then, when running
> org.eclipse.emf.cdo.examples.hibernate.server/CDOHibernateServer.launch
> again I get the error message
> Any hints?
> Goetz
> ----------------excerpt from console log ----------------------
> [ERROR] Not able to update container columns of CDOResource with id
> java.lang.IllegalStateException: Not able to update container columns of
> CDOResource with id
> at
> org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.repairResourceIDs(HibernateStoreAccessor.java:746)
> at
> org.eclipse.emf.cdo.server.internal.hibernate.HibernateStoreAccessor.doWrite(HibernateStoreAccessor.java:669)
> at
> org.eclipse.emf.cdo.spi.server.StoreAccessorBase.write(StoreAccessorBase.java:149)
> at
> org.eclipse.emf.cdo.internal.server.TransactionCommitContext.write(TransactionCommitContext.java:425)
> at
> org.eclipse.emf.cdo.internal.server.Repository.initRootResource(Repository.java:1449)
> at
> org.eclipse.emf.cdo.internal.server.Repository.doActivate(Repository.java:1562)
> at org.eclipse.net4j.util.lifecycle.Lifecycle.activate(Lifecycle.java:72)
> at
> org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:99)
> at
> org.eclipse.net4j.util.lifecycle.LifecycleUtil.activate(LifecycleUtil.java:89)
> at
> org.eclipse.emf.cdo.server.CDOServerUtil.addRepository(CDOServerUtil.java:201)
> at
> org.eclipse.emf.cdo.spi.server.RepositoryConfigurator.configure(RepositoryConfigurator.java:110)
> at
> org.eclipse.emf.cdo.internal.server.bundle.CDOServerApplication.doStart(CDOServerApplication.java:61)
> at org.eclipse.net4j.util.om.OSGiApplication.start(OSGiApplication.java:61)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.equinox.internal.app.AnyThreadAppLauncher.run(AnyThreadAppLauncher.java:26)
> at java.lang.Thread.run(Unknown Source)
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource [message #687226 is a reply to message #687225] |
Thu, 16 June 2011 20:33 |
Good to hear, it was kind of an annoying issue to find... So happy that it is not back :-).
gr. Martin
On 06/16/2011 09:43 PM, Goetz Botterweck wrote:
> On 16/06/2011 19:45, Martin Taal wrote:
>> Hi Goetz,
>> imagine that your version is older (if it is rc4). Can you check the
>> version qualifier of the plugin)?
> For some reason that was a version from April. I started an update (Help
>> Check for Updates) and was offered a new version from 2011-06-07.
> Now the problem is gone :)
> Thanks.
The Netherlands
Re: [CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource [message #687497 is a reply to message #687213] |
Hi Goetz,
plugin)?
gr. Martin
> SHORT STORY
> LONG STORY
> + Hibernate 3.6.0
> I added
> Then, when running
> Any hints?
> Goetz
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> CDOResource with id
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
The Netherlands
Re: [CDO] CDO Hibernate Server causes " Not able to update container columns of CDOResource [message #687502 is a reply to message #687225] |
gr. Martin
>> Hi Goetz,
> Thanks.
The Netherlands
FUDForum. Page generated in 0.04306 seconds
