Re: cdo remove delta [message #687147 is a reply to message #687146] |
Tue, 07 June 2011 08:55 |
Am 07.06.2011 10:40, schrieb Ronald Krijgsheld:
> Hi All,
> We are using a version of CDO from a few months ago. We now run into the following problem. The CDORemoveFeatureDeltaImpl is index based.
What exactly is that problem?
> How is it possible to always remove the correct element when an update is received from the server.
Is that a question? I don't understand it ;-(
> At the moment I think sometimes the wrong element is changed because the updates from the server has changed the underlying list and applying the CDORemoveDelta removes the wrong element.
What makes you think that?
> Is this code still used in the current version of CDO?
You neither specified what code nor what version you're using exactly. It's best that you use Eclipse's team functions to compare the piece of code you're looking at.
Cheers
/Eike
http://www.esc-net.de
Cheers
/Eike
Re: cdo remove delta [message #687393 is a reply to message #687146] |
> Hi All,
Cheers
/Eike
Cheers
/Eike
FUDForum. Page generated in 0.03796 seconds
