Re: Footer at bottom of last page only in BIRT PDF report [message #686663 is a reply to message #686114] |
Wed, 22 June 2011 17:17 |
Are you using the /frameset mapping with __format=pdf?
http://127.0.0.1:52472/viewer/frameset?__report=C%3A%5Cwork%5Cworkspaces%5C2.3.2workspaces%5CBIRT+-+Reports%5CBirtEventHandlersReports%5Cbook%5Cscript%5Cmasterpage%5Cfirstpageonly.rptdesign&__format=pdf&__svg=true&__locale=en&__timezone=US%2FMichigan&__masterpage=true&__rtl=false&__cubememsize=10&__resourceFolder=C%3A%2Fwork%2Fworkspaces%2F2.3.2workspaces%2FBIRT+-+Reports%2FBIRT+Reports%2Fresources%2F&__dpi=96&-1084488416
Jason
Re: Footer at bottom of last page only in BIRT PDF report [message #687705 is a reply to message #687600] |
Thu, 23 June 2011 03:52 |
You could add two computed columns, one that contains current row count and another that has the total number of rows. You could store these values in the oncreate of the table row and check them in you header/footer script. If totalrows-currentrow > pageBreakInterval (for the table) you know you will have more pages.
See attached example.
Jason
Re: Footer at bottom of last page only in BIRT PDF report [message #687712 is a reply to message #687705] |
Thu, 23 June 2011 04:13 |
besides the last post you could try:
set the report to fixed layout (general properties for the report) and put everything in the report in a two row grid and size the grid to your page size.
Put the last page footer in the second row and size it accordingly. Also set align bottom on second row of grid. See attached example.
Also notice I cleared the header and footer height on master page.
Jason
FUDForum. Page generated in 0.03814 seconds
