Re: Problem with OCL forall primitive [message #68770 is a reply to message #68629] |
Sat, 14 March 2009 18:19 |
Originally posted by: give.a.damus.gmail.com
Hi, Olivier,
It looks like you have simply misspelled the forAll iterator: it has a
capital "A."
The confusing error message is caused by the construction of the OCL
grammar: only iterator expressions have vertical bars ("|"), and the
set of iterators is fixed and know at the grammar level. So, "forall"
was assumed to be an operation, which would not have a bar in it.
HTH,
Christian
Olivier BERNARD wrote:
> Hi all,
> After some days spent in the newsgroups, I could finally make the
> example presented in the paper "Implementing Model Integrity in EMF with
> MDT OCL" work with Eclipse 3.4.
> I extented the example with very simple classes A,B,C just to try to
> better understand OCL (I'm new in both OCL & Eclipse):
> B,C inherit from A
> B has an association "c_list" with C (no containment)
> C has attribute - isOK
> - isNotOK, derived as an OCL expression "not isOK" // indeed !
> If in the OCL console (very helpful !), I execute:
> self.c_list->exists(c | c.isOK)
> or self.c_list->exists(c: C | c.isOK)
> I get a correct result (i.e. if at least one C object in c_list is Ok, I
> get "true").
> The problem is with the forall primitive. I copy/paste the previous
> command (with exists) and replace "exists" by "forall". I get:
> => self.c_list->forall(c: C | c.isOK)
> I get the error message:
> ": self.c_list->forall(" misplaced construct(s)
> If I use the alternative
> => self.c_list->forall(c | c.isOK)
> 1:25:1:25 "::" expected instead of "|"
> Could someone tell me what is wrong ?
> -- Olivier
FUDForum. Page generated in 0.03274 seconds
