LogFilter.isLoggable threw a non-fatal unchecked exception [message #683895] |
Tue, 14 June 2011 15:58 |
Rafael Angarita Messages: 94 Registered: November 2010 |
Member |
Hello everybody,
I just started using Eclipse Indigo and then, I get this exception:
LogFilter.isLoggable threw a non-fatal unchecked exception as follows:
at org.eclipse.core.internal.runtime.Log.isLoggable(Log.java:101)
at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.safeIsLoggable(ExtendedLogReaderServiceFactory.java:57)
at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:158)
at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:146)
at org.eclipse.equinox.log.internal.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
at org.eclipse.equinox.log.internal.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
at org.eclipse.equinox.log.internal.LoggerImpl.log(LoggerImpl.java:54)
at org.eclipse.core.internal.runtime.Log.log(Log.java:60)
at altagracia.services.eclipse.ExceptionHandler.handle(ExceptionHandler.java:17)
at altagracia.plugin.wizards.Connect.getTableFromAttributes(Connect.java:321)
at altagracia.codegen.unifier.ProcedureSpec.statementSpec(ProcedureSpec.java:962)
at altagracia.codegen.unifier.ProcedureSpec.blockSpec(ProcedureSpec.java:750)
at altagracia.codegen.unifier.ProcedureSpec.generate(ProcedureSpec.java:231)
at altagracia.codegen.unifier.ProcedureSpec.generate(ProcedureSpec.java:165)
at altagracia.plugin.popup.actions.ActionProcedureGeneration.run(ActionProcedureGeneration.java:46)
at org.eclipse.ui.actions.ActionDelegate.runWithEvent(ActionDelegate.java:70)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginAction.java:241)
at org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1258)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3586)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3207)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2696)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2660)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2494)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:674)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:667)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:123)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
This is my code to handle and log exceptions:
import org.eclipse.core.runtime.Status;
import altagracia.services.IException;
import altagracia.services.IService;
public class ExceptionHandler extends org.eclipse.core.runtime.Plugin implements IException, IService{
public void handle(Exception e) {
getLog().log(new Status(Status.ERROR, "Altagracia", e.getClass().getName(), e));
public void handle(String message, Exception e) {
getLog().log(new Status(Status.ERROR, "Altagracia", message, e));
I generate the exception this way:
Exception e = new Exception("Base table not found ");
Services.Exception.handle("Problems with Base Table ",e);
throw e;
I was working fine before I move to Indigo, so I don't know if I am missing something.
Thank you very much for your help!
Re: LogFilter.isLoggable threw a non-fatal unchecked exception [message #692873 is a reply to message #689376] |
Tue, 05 July 2011 11:43 |
the suu Messages: 1 Registered: July 2011 |
Same here:
using Eclipse Indigo CDT on Red Hat Linux Enterprise 6(64Bit).
It seems not only to notice me every couple of seconds in the terminal,
i also believe thats why i'm experience severe performance issues as well!
I think i will go back for now since Indigo seems very unstable at the moment
at least when i comes to C++ development.
Little excerpt from my terminal (running like 1h):
at org.tigris.subversion.clientadapter.javahl.Activator.isAvailable(Activator.java:92)
at org.tigris.subversion.clientadapter.javahl.Activator.getVersionSynchronized(Activator.java:79)
at org.tigris.subversion.clientadapter.javahl.Activator.getVersionString(Activator.java:74)
at org.tigris.subversion.clientadapter.javahl.Activator.getDisplayName(Activator.java:104)
at org.tigris.subversion.subclipse.ui.preferences.SVNPreferencesPage.<init>(SVNPreferencesPage.java:103)
at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:57)
at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
at java.lang.reflect.Constructor.newInstance(Constructor.java:532)
at java.lang.Class.newInstance0(Class.java:372)
at java.lang.Class.newInstance(Class.java:325)
at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI.createExecutableExtension(RegistryStrategyOSGI.java:184)
at org.eclipse.core.internal.registry.ExtensionRegistry.createExecutableExtension(ExtensionRegistry.java:905)
at org.eclipse.core.internal.registry.ConfigurationElement.createExecutableExtension(ConfigurationElement.java:243)
at org.eclipse.core.internal.registry.ConfigurationElementHandle.createExecutableExtension(ConfigurationElementHandle.java:55)
at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(WorkbenchPlugin.java:260)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceNode.createPage(WorkbenchPreferenceNode.java:47)
at org.eclipse.jface.preference.PreferenceDialog.createPage(PreferenceDialog.java:1339)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.createPage(FilteredPreferenceDialog.java:376)
at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1230)
at org.eclipse.ui.internal.dialogs.FilteredPreferenceDialog.showPage(FilteredPreferenceDialog.java:674)
at org.eclipse.jface.preference.PreferenceDialog$10.run(PreferenceDialog.java:708)
at org.eclipse.jface.preference.PreferenceDialog$9.selectionChanged(PreferenceDialog.java:704)
at org.eclipse.jface.viewers.StructuredViewer$3.run(StructuredViewer.java:888)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.firePostSelectionChanged(StructuredViewer.java:886)
at org.eclipse.jface.viewers.StructuredViewer.handlePostSelect(StructuredViewer.java:1226)
at org.eclipse.jface.viewers.StructuredViewer$5.widgetSelected(StructuredViewer.java:1251)
at org.eclipse.jface.util.OpenStrategy.firePostSelectionEvent(OpenStrategy.java:262)
at org.eclipse.jface.util.OpenStrategy.access$5(OpenStrategy.java:256)
at org.eclipse.jface.util.OpenStrategy$3.run(OpenStrategy.java:433)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:135)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:3563)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3212)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.ui.internal.dialogs.WorkbenchPreferenceDialog.open(WorkbenchPreferenceDialog.java:215)
at org.eclipse.ui.internal.handlers.ShowPreferencePageHandler.execute(ShowPreferencePageHandler.java:54)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:241)
at org.eclipse.ui.internal.actions.CommandAction.runWithEvent(CommandAction.java:157)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3588)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3209)
at org.eclipse.core.runtime.internal.adaptor.EclipseLogFactory$1.log(EclipseLogFactory.java:53)
at org.eclipse.osgi.util.NLS.log(NLS.java:357)
at org.eclipse.osgi.util.NLS.computeMissingMessages(NLS.java:287)
at org.eclipse.osgi.util.NLS.load(NLS.java:336)
at org.eclipse.osgi.util.NLS.initializeMessages(NLS.java:140)
at org.tigris.subversion.subclipse.tools.usage.preferences.PreferencesMessages.<clinit>(PreferencesMessages.java:34)
at org.tigris.subversion.subclipse.tools.usage.preferences.UsageReportPreferencePage.getCheckBoxlabel(UsageReportPreferencePage.java:70)
at org.tigris.subversion.subclipse.tools.usage.preferences.UsageReportPreferencePage.createContents(UsageReportPreferencePage.java:55)
at org.eclipse.jface.preference.PreferencePage.createControl(PreferencePage.java:232)
at org.eclipse.jface.preference.PreferenceDialog.createPageControl(PreferenceDialog.java:1501)
at org.eclipse.jface.preference.PreferenceDialog$14.run(PreferenceDialog.java:1258)
at org.eclipse.jface.preference.PreferenceDialog.showPage(PreferenceDialog.java:1252)
at org.eclipse.cdt.core.CCorePlugin.log(CCorePlugin.java:1359)
at org.eclipse.cdt.internal.formatter.CCodeFormatter.format(CCodeFormatter.java:161)
at org.eclipse.cdt.internal.corext.util.CodeFormatterUtil.format(CodeFormatterUtil.java:129)
at org.eclipse.cdt.internal.ui.text.CFormattingStrategy.format(CFormattingStrategy.java:62)
at org.eclipse.jface.text.formatter.MultiPassContentFormatter.formatMaster(MultiPassContentFormatter.java:193)
at org.eclipse.jface.text.formatter.MultiPassContentFormatter.format(MultiPassContentFormatter.java:135)
at org.eclipse.jface.text.source.SourceViewer.doOperation(SourceViewer.java:973)
at org.eclipse.jface.text.source.projection.ProjectionViewer.doOperation(ProjectionViewer.java:1451)
at org.eclipse.cdt.internal.ui.editor.CSourceViewer.doOperation(CSourceViewer.java:387)
at org.eclipse.cdt.internal.ui.editor.CEditor$AdaptedSourceViewer.doOperation(CEditor.java:357)
at org.eclipse.ui.texteditor.TextOperationAction$1.run(TextOperationAction.java:128)
at org.eclipse.ui.texteditor.TextOperationAction.run(TextOperationAction.java:126)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at org.eclipse.ui.commands.ActionHandler.execute(ActionHandler.java:185)
at org.eclipse.ui.internal.handlers.LegacyHandlerWrapper.execute(LegacyHandlerWrapper.java:109)
at org.eclipse.ui.internal.keys.WorkbenchKeyboard.executeCommand(WorkbenchKeyboard.java:468)
[Updated on: Tue, 05 July 2011 11:44] Report message to a moderator
FUDForum. Page generated in 0.03976 seconds
