Home » Archived » M2M (model-to-model transformation) » [ATL] Model Formalisms
[ATL] Model Formalisms [message #68408] Mon, 10 December 2007 06:38 Go to next message
Originally posted by: irbull.cs.uvic.ca
Hi everyone,
Does anyone know of any good references around model transformation
formalisms and in particular the formalisms of model transformed using
languages ``like'' ATL?
What I mean is, given a Model a and Model b (with MMa and MMb) and a
transformation T (from MMa to MMb), is there anything we can say about
MMb with respect to MMa. (Is it some sort of subset, etc...). I am
trying to understand if there is any way of determining formally if a
transformation is possible or impossible.
i.e. If MMb is a subset of MMa is it always possible? etc...
any tips or pointers would be great.
Ian
Re: [ATL] Model Formalisms [message #68441 is a reply to message #68408] Mon, 10 December 2007 09:35 Go to previous messageGo to next message
Originally posted by: mikael.barbero.gmail.com
Hi Ian,
AFAIK, we can consider a transformation T as a partial function (total
or not) defined by the mapping written in ATL for instance. MMa and MMb
only are domain and codomain of this function. I don't think we can
consider more properties between MMb and MMa in the general case.
Hope this helps.
Mikael
Ian Bull wrote:
> Hi everyone,
> Ian
Mikaël Barbero - PhD Candidate
ATLAS Group (INRIA & LINA) - University of Nantes
2, rue de la Houssinière
44322 Nantes Cedex 3 - France
tel. +33 2 51 12 58 08 /\ cell.+33 6 07 63 19 00
email: Mikael.Barbero@{gmail.com, univ-nantes.fr}
http://www.sciences.univ-nantes.fr/lina/atl/
Re: [ATL] Model Formalisms [message #68516 is a reply to message #68408] Mon, 10 December 2007 13:32 Go to previous messageGo to next message
Miguel Garcia is currently offline Miguel GarciaFriend
Member
Ian,
Perhaps the following workshop (around verification and validation for MDSD)
is a one-stop-show on current work in the field. Proceedings at
http://www.modeva.org/2007/modevva07.pdf
The charter of that workshop states:
"... Major questions that cross-cut V&V and MDE include: Is the result of a
transformation really what the user intended? Is the model correct with
respect to the expected security, time, and structural constraints? What
models can be used for validation or for verification? Does the
implementation, generated after several model transformations, conform to
the initial requirements? ..."
If I have to choose one paper, my pick is:
Analysis of Model Transformations via Alloy
Kyriakos Anastasakis, Behzad Bordbarand and Jochen M. K
Re: [ATL] Model Formalisms [message #68594 is a reply to message #68441] Tue, 11 December 2007 01:16 Go to previous messageGo to next message
Thanks Mikaël,
Does it necessarily have to be a partial function (i.e. does each
element map to *at most* one element in the codomain). If we use the
impartive part of ATL, can this be broken (because we can always add a
body to a rule that calls other rules to create more than 1 new element)?
Sorry if this doesn't make sense, I have been doing these
transformations for a few years now, but haven't really thought about
them formally until recently.
thanks,
ian
Mikaël Barbero wrote:
> Hi Ian,
> Hope this helps.
> Best regards,
> Mikael
> Ian Bull wrote:
>> Hi everyone,
>> Thanks,
>> Ian
Re: [ATL] Model Formalisms [message #68602 is a reply to message #68516] Tue, 11 December 2007 01:16 Go to previous messageGo to next message
Thanks Miguel,
These links are great!
cheers,
ian
Miguel Garcia wrote:
> Ian,
> Kyriakos Anastasakis, Behzad Bordbarand and Jochen M. Küster
> (pp. 47--56)
> Miguel
> "Ian Bull" <irbull@cs.uvic.ca> wrote in message
> news:fjimsk$8mm$1@build.eclipse.org...
>> Hi everyone,
>> transformation T (from MMa to MMb), is there anything we can say about MMb
>> with respect to MMa. (Is it some sort of subset, etc...). I am trying to
>> understand if there is any way of determining formally if a transformation
>> Thanks,
>> Ian
Re: [ATL] Model Formalisms [message #68721 is a reply to message #68594] Tue, 11 December 2007 10:12 Go to previous messageGo to next message
Ian,
In fact, I was a bit simplifying the problem. First of all, I only
consider *declarative* part of ATL (imperative part only is for some
very specific issues that can not be deal with declarative part and is
not very interesting for reasoning on transformations).
I was also simplifying the case where a rule match only 1 model element
(despite ATL can match more than one) and create one element. I agree
this is over simplification.
If we consider declarative ATL in the large (n,n), we are facing a n-ary
relation. This property may not be very interesting by itself and may
not allow to extract derived properties from the transformation.
I hope this will be helpful to you.
Mikael
Ps: It makes sense ;) but i'm not very formally thinking on model
transformations neither.
Ian Bull wrote:
> Thanks Mikaël,
> thanks,
> ian
>> Hi Ian,
>> MMb only are domain and codomain of this function. I don't think we
>> can consider more properties between MMb and MMa in the general case.
>> Hope this helps.
>> Best regards,
>> Mikael
>> Ian Bull wrote:
>>> Hi everyone,
>>> using languages ``like'' ATL?
>>> about MMb with respect to MMa. (Is it some sort of subset, etc...).
>>> I am trying to understand if there is any way of determining formally
>>> if a transformation is possible or impossible.
>>> Thanks,
>>> Ian
Re: [ATL] Model Formalisms [message #68803 is a reply to message #68721] Tue, 11 December 2007 15:45 Go to previous messageGo to next message
Thanks again.
I assumed you were thinking the declarative part, but I just wanted to
make sure.
The reason I was asking is because I am just finishing my dissertation
on using MDE to create interactive visualizations of information. I
have several MM for for viewers (graphs, charts, heatmaps, etc...) and
using model transformations I can specify how the visualization should
work. I know this works in practice, but I wanted to give some advice
on how well it works in theory (can this always be done, etc...). There
are some cases when I have to use operational (imperative)
transformations, and it usually is a result of needing multiple elements
in the visualizations for a single source.
Thanks for all your help. I did find some good links on this stuff as
well, I will get them organized and post them here in case others have
questions too.
ian
> Ian,
> Best regards,
> Mikael
> Ian Bull wrote:
>> Thanks Mikaël,
>> thanks,
>> ian
>>> Hi Ian,
>>> (total or not) defined by the mapping written in ATL for instance.
>>> MMa and MMb only are domain and codomain of this function. I don't
>>> think we can consider more properties between MMb and MMa in the
>>> general case.
>>> Hope this helps.
>>> Best regards,
>>> Mikael
>>> Ian Bull wrote:
>>>> Hi everyone,
>>>> etc...). I am trying to understand if there is any way of
>>>> determining formally if a transformation is possible or impossible.
>>>> Thanks,
>>>> Ian
Re: [ATL] Model Formalisms [message #68916 is a reply to message #68803] Tue, 11 December 2007 17:49 Go to previous messageGo to next message
Member
Ian,
That topic has to do with another ongoing PhD blogged at
http://visual-languages.blogspot.com/
And there's a very short (2-page) paper also touchign that topic,
"Mapping visual notations to MOF compliant models with QVT Relations"
The URL is http://portal.acm.org/citation.cfm?id=1244228
So I guess we all want to read your dissertation once it's ready :-)
Miguel
news:475EB085.8030502@cs.uvic.ca...
> Thanks again.
> make sure.
> The reason I was asking is because I am just finishing my dissertation on
> using MDE to create interactive visualizations of information. I have
> several MM for for viewers (graphs, charts, heatmaps, etc...) and using
> model transformations I can specify how the visualization should work. I
> know this works in practice, but I wanted to give some advice on how well
> it works in theory (can this always be done, etc...). There are some
> cases when I have to use operational (imperative) transformations, and it
> usually is a result of needing multiple elements in the visualizations for
> a single source.
> questions too.
> Cheers,
> ian
> Mika
Re: [ATL] Model Formalisms [message #69017 is a reply to message #68916] Tue, 11 December 2007 22:50 Go to previous message
Thanks Miguel,
This is a great reference.
I am doing my research in a group focused more on Information
Visualization than MD(E/A/D). It has been a good battle learning all
the modeling technologies, but a lot of fun. My primary research
objective is to determine how MD(E/A/D) can be used in the creation and
customization of interactive information visualization.
For someone learning modeling on their own, newsgroups like this have
been a great resource.
cheers,
ian
> Ian,
> Miguel
>> Thanks again.
>> make sure.
>> a single source.
>> questions too.
>> Cheers,
>> ian
>>> Ian,
>>> consider *declarative* part of ATL (imperative part only is for some very
>>> specific issues that can not be deal with declarative part and is not
>>> relation. This property may not be very interesting by itself and may not
>>> Best regards,
>>> Mikael
>>> Ian Bull wrote:
>>>> Thanks Mikaël,
>>>> element)?
>>>> thanks,
>>>> ian
>>>>> Hi Ian,
>>>>> Hope this helps.
>>>>> Best regards,
>>>>> Mikael
>>>>> Ian Bull wrote:
>>>>>> Hi everyone,
>>>>>> Thanks,
>>>>>> Ian
Previous Topic:[ATL]A strange problem
Next Topic:Semantics of ATL defined?
Current Time: Sat Dec 02 06:53:30 GMT 2023
Powered by FUDForum. Page generated in 0.02334 seconds
