Home » Archived » BIRT » How to make the where clause optional on dataset SQL query??
How to make the where clause optional on dataset SQL query?? [message #683125] Sun, 12 June 2011 23:45 Go to next message
I am working on a report design which has 3 report parameters; all three report parameters are optional. Now my question is, when no report parameters are selected full report should be generated, how that can be achieved (i.e., the where clause on the dataset sQL query should be set as optional)?
I have removed the where clause from the Data Set SQL query, and I think I need to filter the data, but so far not successful. Is there any example that someone can point me to? Any input on this is appreciated.
Thanks in advance,
Jyo
Re: How to make the where clause optional on dataset SQL query?? [message #683149 is a reply to message #683125] Mon, 13 June 2011 01:28 Go to previous messageGo to next message
you can add something like 1=1 to the where clause. This condition will be always true and won't have any affect to the result dataset.
Tomas
(no subject) [message #683231 is a reply to message #683125] Mon, 13 June 2011 05:29 Go to previous messageGo to next message
Originally posted by: Donkey Hottie
13.6.2011 6:45, jyo kirjoitti:
> as optional)?
> Thanks in advance,
> Jyo
You can do something like this
SELECT A,B,C
FROM ABBA
WHERE A = IFNULL(param1,A)
AND B = IFNULL(param2,B)
AND C = IFNULL(param3,C) ;
If Oracle, change IFNULL() to NVL().
You will have a long and boring life.
Re: How to make the where clause optional on dataset SQL query?? [message #683326 is a reply to message #683149] Mon, 13 June 2011 10:21 Go to previous messageGo to next message
Thank you for the reply.
Initially I had query like below:
select A, B, C from table where A=? or B=? or C=?
And I defined 3 optional report parameters rp_A, rp_B, rp_C that can enter on the parameter Page, and I linked the dataset paramters to report parameters and report rendering fine if user selects/enters values for rp_A, rp_B and rp_C. Now my question is, if user doen't select/enter any value for the report parameter; all the data from the table should be dsiplayed on the report;
I tried below two options Thomas and Donkey Hottie provided; but still not working for me, maybe they should be at specific places during report design that I am missing, can yu point me some detail example?
(no subject) [message #683427 is a reply to message #683326] Mon, 13 June 2011 13:21 Go to previous messageGo to next message
In this case I would not use dataset parameters. I would put my query
in like select A, B, C from table
I would then write a beforeOpen script on the dataset that checked the
values of A, B and C and modify the query based on those values.
if( params["A"].value != null ){
this.queryText = this.queryText + " where A="+params["A"].value;
Jason
Re: (no subject) [message #683912 is a reply to message #683427] Tue, 14 June 2011 12:28 Go to previous messageGo to next message
Hi Jason, Thank you for the reply. I am able to build the where clause dynamically. Now I want to extend report design little bit more. One of the report parameter is the list box and user can select multiple values for that. In this situation, I am trying to build the where caluse dynamically. I am wondering how to get the selected values from the listbox into that Dataset's beforeOpen method.
I did search in the forums, but didn't find anything helpful. Any input on this is appreciated. Thanks again.
Re: (no subject) [message #683949 is a reply to message #683427] Tue, 14 June 2011 14:05 Go to previous messageGo to next message
Jason, I am using below snippet of javascript for building the where clause dynamically for list box mutil selected values; I have other two report parameters also, that's why I kept " where " outside the loop. but it is not working I am not sure where I am going wrong...
var parmcount=reportContext.getParameterValue( "listparameter" ).length;
printWriter.println("parmcount is: "+parmcount);
whereclause=whereclause + " where ";
if( parmcount > 0 ){
whereclause =whereclause +"au.tran_au in ('";
for( i=0; i < parmcount; i++ ){
if( i == 0 ){
whereclause = whereclause + params["listparameter"].value[i];
}else{
whereclause = whereclause + "' , '" + params["listparameter"].value[i];
whereclause = whereclause+"')";
this.queryText = this.queryText+whereclause+" ORDER BY au.tran_au";
Re: (no subject) [message #684023 is a reply to message #683949] Tue, 14 June 2011 17:20 Go to previous messageGo to next message
I have done it this way before:
var parmcount = params["parmorders"].value.length
var whereclause = "";
whereclause = " where customernumber in ( ";
if( i == 0 ){
whereclause = whereclause + params["parmorders"].value[i];
}else{
whereclause = whereclause + " , " + params["parmorders"].value[i];
this.queryText = this.queryText + whereclause + " ) ";
My suggestion is to write the final query into a global variable and
then display in on the report to verify it.
reportContext.setGlobablVariable("myquery", this.queryText);
Add a text item to the report after the dataset is used in a table with
this value:
<value-of>
reportContext.getGlobablVariable("myquery");
</value-of>
Make sure you set the type to html for the text element.
Jason
> if( i == 0 ){
> }else{
> whereclause = whereclause + "' , '" + params["listparameter"].value[i]; }
Re: (no subject) [message #684483 is a reply to message #684023] Wed, 15 June 2011 12:34 Go to previous messageGo to next message
Thanks Jason, I am able to debug the javascript and build the dynamic where clause fine...
but I am getting below warning each time when I run the report; can you tell me why Iam getting below error?
RHINO USAGE WARNING: Missed Context.javaToJS() conversion:
Rhino runtime detected object [Ljava.lang.Object;@31d0b9 of class [Ljava.lang.Object; where it expected String, Number, Boolean or Scriptable instance. Please check your code for missing Context.javaToJS() call.
here is the part of snippet of code I am using:
if((params["rp_tran_au"].value == null || params["rp_tran_au"].value == '')
&& (params["rp_net_user_id"].value == null || params["rp_net_user_id"].value == '')
&& (params["rp_usr_id"].value == null || params["rp_usr_id"].value == '')){
this.queryText = this.queryText + " ORDER BY au.tran_au";
}else{
//whereclause=whereclause + " where ";
var parmcount = params["rp_tran_au"].value.length;
if((parmcount == 1)&& (params["rp_tran_au"].value[0] == null | params["rp_tran_au"].value[0] == '') ){
//printWriter.println("No Au seleted");
}else if((parmcount == 1)&& (params["rp_tran_au"].value[0] != null | params["rp_tran_au"].value[0] != '') ){
// printWriter.println("Single Au seleted");
whereclause =whereclause +" where au.tran_au in ('" +params["rp_tran_au"].value[0] +"')";
au_appended=true;
Re: (no subject) [message #684509 is a reply to message #684483] Wed, 15 June 2011 13:18 Go to previous messageGo to next message
Are you sure this error is from the script?
Jason
> params["rp_net_user_id"].value == '') && (params["rp_usr_id"].value ==
> }else{
> au_appended=true;
Re: (no subject) [message #684532 is a reply to message #684509] Wed, 15 June 2011 14:42 Go to previous messageGo to next message
I can't think of anything else...what else it could be?
Re: (no subject) [message #684545 is a reply to message #684532] Wed, 15 June 2011 14:57 Go to previous messageGo to next message
If you remove the script do you get the error?
Re: (no subject) [message #684941 is a reply to message #684545] Thu, 16 June 2011 09:59 Go to previous messageGo to next message
Hi Jason, yes, if I remove the script I won't get that error. I am not sure how big that error is and can it ignored or not. If I let the report run with that error will there be any performance issues? And also not sure why that is happening. I was doing regular javascript...
And also when I deploy the webapp in the tomcat which runs on linux server, the logs are writing to the catalina.out even though the ReportEngine<timestamp>.log (which gets created each time I restart the server) file gets created under the directory BIRT_VIEWER_LOG_DIR I specified in web.xml; but those files remain empty. In my local machine (windows) the logs are writing to ReportEngine<timestamp>.log.
Thanks in advance,
Jyo
Re: (no subject) [message #684958 is a reply to message #684941] Thu, 16 June 2011 10:17 Go to previous messageGo to next message
When you run the attached report do you get the error?
Jason
> Thanks in advance,
> Jyo
(no subject) [message #684961 is a reply to message #684545] Thu, 16 June 2011 09:59 Go to previous messageGo to next message
Thanks in advance,
Jyo
Re: (no subject) [message #684964 is a reply to message #684941] Thu, 16 June 2011 10:17 Go to previous messageGo to next message
Jason
> Thanks in advance,
> Jyo
Re: (no subject) [message #684974 is a reply to message #684964] Thu, 16 June 2011 10:41 Go to previous messageGo to next message
No, I am not getting that error with the attached report.
So, issue is in my script??
Re: (no subject) [message #684981 is a reply to message #684974] Thu, 16 June 2011 10:49 Go to previous messageGo to next message
I thought your script was similar to the one I used in that report.
On 6/16/2011 10:41 AM, jyo wrote:
> No, I am not getting that error with the attached report. So, issue is
> in my script??
Re: (no subject) [message #685444 is a reply to message #684981] Fri, 17 June 2011 10:21 Go to previous messageGo to next message
Hi Jason, I wanted to touch base with you on this. Even I feel my script is very simple and similar to yours, but I am getting RHINO USAGE WARNING. Can you point me by seeing below why I am getting that warning?
rp_tran_au - is list box field with multi selection
rp_net_user_id - is a text box
rp_usr_id - is a text box
var au_appended=false;
var netuserAppended=false;
}else{
//printWriter.println("The param count is: " +parmcount);
whereclause =whereclause +"au.tran_au in ('" +params["rp_tran_au"].value[0] +"')";
au_appended=true;
}else if ( parmcount > 1 ){
if( i == 0 && params["rp_tran_au"].value[i] != null){
whereclause = whereclause + params["rp_tran_au"].value[i];
}else{
whereclause = whereclause + "' , '" + params["rp_tran_au"].value[i];
au_appended=true;
if(params["rp_net_user_id"].value != null && params["rp_net_user_id"].value != ''){
if(au_appended){
whereclause = whereclause + " and net_user_id='" +params["rp_net_user_id"].value+"'";
netuserAppended=true;
}else if(!au_appended){
whereclause = whereclause + "net_user_id='" +params["rp_net_user_id"].value+"'";
if(params["rp_usr_id"].value != null && params["rp_usr_id"].value != ''){
if(au_appended || netuserAppended){
whereclause = whereclause + " and usr_id='" +params["rp_usr_id"].value+"'";
}else if (!au_appended && !netuserAppended){
whereclause = whereclause + " usr_id='" +params["rp_usr_id"].value+"'";
//printWriter.println("The query is :" + this.queryText);
Thank you!
jyo
Re: (no subject) [message #685450 is a reply to message #685444] Fri, 17 June 2011 10:28 Go to previous messageGo to next message
Can you trim this script a little at a time to determine which if
statement is causing the issue?
Jason
> }else{
> au_appended=true;
> }else{
> whereclause = whereclause + "' , '" + params["rp_tran_au"].value[i]; }
> au_appended=true;
> if(au_appended){
> Thank you!
> jyo
Re: (no subject) [message #688455 is a reply to message #685450] Fri, 24 June 2011 14:29 Go to previous messageGo to next message
Jason Weathersby wrote on Fri, 17 June 2011 10:28
Jason, below is causing that RHINO USAGE WARNING. In my report rp_tran_au is an optional parameter.
if((params["rp_tran_au"].value == null || params["rp_tran_au"].value == '')){}
How to avoid that if I want to use above condition in my report?
Thanks!
Re: (no subject) [message #688464 is a reply to message #688455] Fri, 24 June 2011 14:46 Go to previous messageGo to next message
If you remove one of the or conditions does the error still happen? What is the datatype of the parameter?
Jason
Re: (no subject) [message #688515 is a reply to message #688464] Fri, 24 June 2011 16:42 Go to previous messageGo to next message
Jason Weathersby wrote on Fri, 24 June 2011 14:46
Jason
If I remove the condition error doesn't happen and that parameter is string data type. I just wonder how can I handle that...
Re: (no subject) [message #688536 is a reply to message #688515] Fri, 24 June 2011 17:45 Go to previous messageGo to next message
What is the parameter type? Did you try removing each condition individually?
if((params["rp_tran_au"].value == null |){}
then
if((params["rp_tran_au"].value == '')){}
To see which condition is the issue.
Jason
Re: (no subject) [message #691100 is a reply to message #688536] Thu, 30 June 2011 13:47 Go to previous messageGo to next message
Jason Weathersby wrote on Fri, 24 June 2011 17:45
then
Jason
Hi Jason, After debug I came to know that below condition causing the RHINO USAGE WARNING....And can you correct the syntax I am using?
Thx!
Re: (no subject) [message #691115 is a reply to message #691100] Thu, 30 June 2011 14:04 Go to previous message
What data type is rp_tran_au?
Also do you check it for null first and then check the value?
Jason
>> individually?
>> then
>> Jason
> Thx!
Previous Topic:BIRT Chart interactivity - drilldown from x-axis label
Next Topic:Report of a database schema
Current Time: Sat Jul 05 05:48:41 EDT 2025
Powered by FUDForum. Page generated in 0.07826 seconds
