Home » Archived » BIRT » (no subject)
(no subject) [message #682217 is a reply to message #682143] |
Fri, 10 June 2011 16:19 |
Robert,
Can you use a text element instead of the dynamic text? Set its type to
HTML.
Jason
On 6/10/2011 9:27 AM, Robert Aust wrote:
> Hi there,
> I have a small dynamic text-field with some javaScript in it, e.g.
> ...doCheckBox(row['COL_A']);
> which 'draws' a Checkbox-representation based on the given Value [On/Off].
> Is there a way to resize the size of the field in the designer or even
> to give it a 'display-name' to use in Designer?
> E.g. show it in designer as 'CHKBOX_A' - or so?
> Currently the size in the designer seems to depend on the code inside it
> and that makes the layout somewhat unclear / cluttered.
> btw - I'm using Birt 2.5.2.
> Thanks for any help.
> Robert
(no subject) [message #682332 is a reply to message #682304] |
Fri, 10 June 2011 20:34 |
If you use a text element it should not matter how much text is in it,
it should show the same size if you set the type to html. I am not
certain what the issue is.
Jason
On 6/10/2011 3:40 PM, Robert Aust wrote:
> Hi Jason,
> I tried that.
> Both fields : dynamic text and text with content 'html' show the same
> bahaviour, wehn I put the javascript-cose in it.
> The size and display-name in designer can not be changed.
> I tried to set 'Display Name' in advanced properties - but with no effect.
> best regards,
> Robert
> Am 10.06.2011 18:19, schrieb Jason Weathersby:
>> Robert,
>> HTML.
>> Jason
>>> Hi there,
>>> [On/Off].
>>> Robert
(no subject) [message #682631 is a reply to message #682332] |
Sat, 11 June 2011 17:40 |
Robert Aust Messages: 17 Registered: July 2009 |
Hi Jason,
It is just a designer issue, that i have small cells in a table, that
use javascript-code to generate the content.
It is not possible to reduce the size of the text/data-element to the
size of the table-cell or to give it a display-name, it will always show
the javascript-code as content in designer.
This is the case for both, text- and dynamic-text fields :
for example, these two have the same behaviour and the provided display
name has no effect in designer.
<cell id="342">
<property name="style">wgwValueCell</property>
<property name="textAlign">center</property>
<text-data id="1627">
<text-property name="displayName">BBB</text-property>
<expression name="valueExpr">doCheckbox(row["YN_COL_A"])</expression>
<property name="contentType">html</property>
</text-data>
</cell>
<cell id="343">
<text id="2881">
<text-property name="displayName">AAA</text-property>
<property name="display">block</property>
<text-property
name="content"><![CDATA[doCheckbox(row["YN_COL_A"])]]></text-property>
</text>
</cell>
It's not a real problem - I was just wandering, if I did something wrong.
best regards,
Robert
Am 10.06.2011 22:34, schrieb Jason Weathersby:
> Jason
>> Hi Jason,
>> I tried that.
>> effect.
>> best regards,
>> Robert
>>> Robert,
>>> HTML.
>>> Jason
>>>> Hi there,
>>>> [On/Off].
>>>> inside it
>>>> Robert
(no subject) [message #683301 is a reply to message #682631] |
Mon, 13 June 2011 13:27 |
Robert
You have not done anything wrong. If you have any ideas on how it would
look better, feel free to log an enhancement in bugzilla.
Jason
On 6/11/2011 1:40 PM, Robert Aust wrote:
> Hi Jason,
> <cell id="342">
> </text-data>
> </cell>
> <cell id="343">
> <text id="2881">
> <text-property
> </text>
> </cell>
> best regards,
> Robert
>> Jason
>>> Hi Jason,
>>> I tried that.
>>> effect.
>>> best regards,
>>> Robert
>>>> Robert,
>>>> HTML.
>>>> Jason
>>>>> Hi there,
>>>>> [On/Off].
>>>>> inside it
>>>>> Robert
Current Time: Thu Sep 19 09:38:16 GMT 2024
Powered by FUDForum. Page generated in 0.05123 seconds
