Home » Archived » BIRT » custom chart : multiple Y values for same X value
custom chart : multiple Y values for same X value [message #682062] |
Fri, 10 June 2011 10:01 |
Originally posted by: Dennis Schladebeck
i am currently trying to create a new chart type. Now i was wondering how
i could make BIRT not using aggregate functions on my Value(Y) series.
By default it is always the "sum" function. Is there a way to allow selection of
NONE in the aggregation combo ?
My dataset could be sth like
x / y
1 / 10
2 / 10
2 / 30
3 / 5
etc.
I my IDataSetProcessor i added the ids to getDataDefIdsForGrouping(). But now the two Y values at 2 are always
added to each other. So there is one datapoint 2 / 40 when doing my rendering.
thx for any advice
Dennis
Re: custom chart : multiple Y values for same X value [message #682209 is a reply to message #682062] |
Fri, 10 June 2011 15:53 |
Dennis,
If you disable grouping on the category series the default aggregation
for the y axis will be none. To test this open the chart wizard and
select a bar chart. Select the aggregation on the x-axis in the data
tab and un-check the grouping enabled checkbox.
Jason
On 6/10/2011 6:01 AM, Dennis Schladebeck wrote:
> selection of
> x / y
> 1 / 10
> 2 / 10
> 2 / 30
> 3 / 5
> etc.
> rendering.
> thx for any advice
> Dennis
Re: custom chart : multiple Y values for same X value [message #683936 is a reply to message #682209] |
Tue, 14 June 2011 17:01 |
Hi Jason,
thanks for the hint. It seems to be working for my chart now. I had to implement the getSeries Method
in my chart. Now the chart runs nicely in the reportdesigner, but i am getting another error,
when running in headless runtime:
My birt version is 2.5.2
WARNUNG: handle type: org.eclipse.birt.report.model.api.OdaDataSetHandle
14.06.2011 18:56:27 org.eclipse.birt.report.engine.api.impl.RunAndRenderTask doR
un
SCHWERWIEGEND: An error happened while running the report. Cause:
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.add
ValueSeriesAggregateBindingForGrouping(AbstractChartBaseQueryGenerator.java:158)
AggregateBindings(AbstractChartBaseQueryGenerator.java:587)
at org.eclipse.birt.chart.reportitem.AbstractChartBaseQueryGenerator.gen
erateExtraBindings(AbstractChartBaseQueryGenerator.java:345)
at org.eclipse.birt.chart.reportitem.ChartBaseQueryHelper.createBaseQuer
y(ChartBaseQueryHelper.java:109)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createQuer
y(ChartReportItemQueryImpl.java:159)
at org.eclipse.birt.chart.reportitem.ChartReportItemQueryImpl.createRepo
rtQueries(ChartReportItemQueryImpl.java:102)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder$QueryBuild
erVisitor.visitExtendedItem(ReportQueryBuilder.java:689)
at org.eclipse.birt.report.engine.ir.ExtendedItemDesign.accept(ExtendedI
temDesign.java:45)
at org.eclipse.birt.report.engine.data.dte.ReportQueryBuilder.build(Repo
rtQueryBuilder.java:256)
rtQueryBuilder.java:237)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.prepare(Ab
stractDataEngine.java:178)
at org.eclipse.birt.report.engine.executor.ReportExecutor.execute(Report
Executor.java:123)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportEx
ecutor.execute(WrappedReportExecutor.java:60)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplciat
eReportExecutor.execute(SuppressDuplciateReportExecutor.java:42)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReport
Executor.execute(LocalizedReportExecutor.java:61)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doRun(RunAnd
RenderTask.java:168)
at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run(RunAndRe
nderTask.java:75)
at org.eclipse.birt.report.engine.api.ReportRunner.runAndRenderReport(Re
portRunner.java:222)
at org.eclipse.birt.report.engine.api.ReportRunner.execute(ReportRunner.
java:162)
at org.eclipse.birt.report.engine.api.ReportRunner.main(ReportRunner.jav
a:121)
14.06.2011 18:56:27 org.eclipse.birt.report.engine.api.ReportRunner runAndRender
Report
SCHWERWIEGEND: Error happened while running the report
org.eclipse.birt.report.engine.api.EngineException: Error happened while running
the report
RenderTask.java:186)
nderTask.java:75)
java:162)
a:121)
temDesign.java:45)
Executor.java:123)
... 4 more
On 10.06.2011 17:53, Jason Weathersby wrote:
> Dennis,
> If you disable grouping on the category series the default aggregation for the y axis will be none. To test this open the chart wizard and select a
> bar chart. Select the aggregation on the x-axis in the data tab and un-check the grouping enabled checkbox.
> Jason
>> Hi,
>> selection of
>> x / y
>> 1 / 10
>> 2 / 10
>> 2 / 30
>> 3 / 5
>> etc.
>> rendering.
>> thx for any advice
>> Dennis
Re: custom chart : multiple Y values for same X value [message #684024 is a reply to message #683936] |
Tue, 14 June 2011 21:23 |
Dennis
It looks like something is messed up in the chart item binding. Can you
reproduce the issue with data that I can run?
Jason
On 6/14/2011 1:01 PM, Dennis Schladebeck wrote:
> Hi Jason,
> 14.06.2011 18:56:27
> un
> temDesign.java:45)
> Executor.java:123)
> nderTask.java:75)
> java:162)
> a:121)
> runAndRender
> Report
> running
> the report
> nderTask.java:75)
> java:162)
> a:121)
> temDesign.java:45)
> Executor.java:123)
> ... 4 more
>> Dennis,
>> select a
>> Jason
>>> Hi,
>>> how
>>> selection of
>>> x / y
>>> 1 / 10
>>> 2 / 10
>>> 2 / 30
>>> 3 / 5
>>> etc.
>>> rendering.
>>> thx for any advice
>>> Dennis
Re: custom chart : multiple Y values for same X value [message #684174 is a reply to message #684024] |
Wed, 15 June 2011 06:15 |
the error is occuring using my own chart implementation. Using same data etc. with BarChart works.
It is in the method
AbstractChartBaseQueryGenerator.addValueSeriesAggregateBindingForGrouping
The line
Series series = orthSD.getDesignTimeSeries( );
returns null for series, which causes NPE in the following lines calling
series.getClass( )
This only happens when running my report in the birt runtime using ReportRunner. Running it in the rcp designer works fine.
To create my chart extension, i used the example you send me a while ago.
I noticed i get the same error, when my new chart plugin is not placed in the plugins folder of the runtime. Now i am
wondering when birt first accesses the extensions and if maybe my chart leads to invalid rtpdesign file. But then running
the report from ReportDesingner shouldn't work, which it does.
Dennis
On 14.06.2011 23:23, Jason Weathersby wrote:
> Dennis
> It looks like something is messed up in the chart item binding. Can you reproduce the issue with data that I can run?
> Jason
>> Hi Jason,
>> 14.06.2011 18:56:27
>> un
>> temDesign.java:45)
>> Executor.java:123)
>> nderTask.java:75)
>> java:162)
>> a:121)
>> runAndRender
>> Report
>> running
>> the report
>> nderTask.java:75)
>> java:162)
>> a:121)
>> temDesign.java:45)
>> Executor.java:123)
>> ... 4 more
>>> Dennis,
>>> select a
>>> Jason
>>>> Hi,
>>>> how
>>>> selection of
>>>> x / y
>>>> 1 / 10
>>>> 2 / 10
>>>> 2 / 30
>>>> 3 / 5
>>>> etc.
>>>> rendering.
>>>> thx for any advice
>>>> Dennis
Re: custom chart : multiple Y values for same X value [message #684175 is a reply to message #684174] |
Wed, 15 June 2011 06:42 |
here is my rptdesign file und the used data, hoping it helps.
Dennis
On 15.06.2011 08:15, Dennis Schladebeck wrote:
> It is in the method
> The line
> series.getClass( )
> Dennis
>> Dennis
>> Jason
>>> Hi Jason,
>>> 14.06.2011 18:56:27
>>> un
>>> temDesign.java:45)
>>> Executor.java:123)
>>> nderTask.java:75)
>>> java:162)
>>> a:121)
>>> runAndRender
>>> Report
>>> running
>>> the report
>>> nderTask.java:75)
>>> java:162)
>>> a:121)
>>> temDesign.java:45)
>>> Executor.java:123)
>>> ... 4 more
>>>> Dennis,
>>>> select a
>>>> Jason
>>>>> Hi,
>>>>> how
>>>>> selection of
>>>>> x / y
>>>>> 1 / 10
>>>>> 2 / 10
>>>>> 2 / 30
>>>>> 3 / 5
>>>>> etc.
>>>>> rendering.
>>>>> thx for any advice
>>>>> Dennis
x,y,width,height,text_x,text_y,text,fill
10,30,6,4,0,0,"","1"
35,50,5,3,0,0,"Opt","2"
35,40,6,3,0,0,"","3"
50,30,8,5,0,0,"","4"
60,10,5,3,0,0,"<Min","R255G128B064"
75,75,8,4,0,0,"","5"
80,60,6,2,0,0,"Opt","6"
90,90,6,4,0,0,">Max","R255G128B064"
Re: custom chart : multiple Y values for same X value [message #684397 is a reply to message #684175] |
Wed, 15 June 2011 14:09 |
Dennis,
Can you post the manifest file for your chart extension?
Jason
On 6/15/2011 2:42 AM, Dennis Schladebeck wrote:
> Dennis
>> Hi,
>> It is in the method
>> The line
>> series.getClass( )
>> Dennis
>>> Dennis
>>> Jason
>>>> Hi Jason,
>>>> 14.06.2011 18:56:27
>>>> un
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> temDesign.java:45)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Executor.java:123)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> nderTask.java:75)
>>>> at
>>>> at
>>>> java:162)
>>>> at
>>>> a:121)
>>>> runAndRender
>>>> Report
>>>> while
>>>> running
>>>> the report
>>>> at
>>>> at
>>>> nderTask.java:75)
>>>> at
>>>> at
>>>> java:162)
>>>> at
>>>> a:121)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> temDesign.java:45)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Executor.java:123)
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 4 more
>>>>> Dennis,
>>>>> select a
>>>>> Jason
>>>>>> Hi,
>>>>>> how
>>>>>> series.
>>>>>> selection of
>>>>>> x / y
>>>>>> 1 / 10
>>>>>> 2 / 10
>>>>>> 2 / 30
>>>>>> 3 / 5
>>>>>> etc.
>>>>>> rendering.
>>>>>> thx for any advice
>>>>>> Dennis
Re: custom chart : multiple Y values for same X value [message #684401 is a reply to message #684397] |
Wed, 15 June 2011 14:28 |
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Rectangle Chart
Bundle-SymbolicName: de.bredex.birt.rectangle.chart;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: de.bredex.birt.rectangle.chart.Activator
Bundle-Vendor: Bredex GmbH
Require-Bundle: org.eclipse.ui;resolution:=optional,
org.eclipse.core.runtime;resolution:=optional,
org.eclipse.emf.ecore;resolution:=optional,
org.eclipse.emf.ecore.xmi;resolution:=optional,
org.eclipse.birt.chart.engine,
org.eclipse.birt.chart.engine.extension,
org.eclipse.birt.chart.ui;resolution:=optional,
org.eclipse.birt.chart.ui.extension;resolution:=optional,
com.ibm.icu
Bundle-ActivationPolicy: lazy
Current Time: Fri Apr 26 21:03:01 GMT 2024
Powered by FUDForum. Page generated in 0.03117 seconds
