Home » Eclipse Projects » Riena » Milestone 1.0.0.M3
Re: Milestone 1.0.0.M3 [message #6055 is a reply to message #6038] |
Thu, 03 July 2008 10:41 |
Originally posted by: ekkehard.gentz-software.de
great news, christian :-)
you can be sure, I'll test immediatly if the concept of your UI
and navigation wull fit into my project (I hope so)
would be really great if
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232942
can be fixed, because its a blocker for me -
without supporting Java 5 Enumerations its problematic for me
to use ObjectTransactions (and I like your OTs :-)
I think I'm not the only one using Java 5 enums in a business
application ;-)
ekke
Christian Campo schrieb:
> Hi Riena-users,
> the plan for Riena contains a M3 milestone at the end of august. However
> we thought that it would be good to come up with some milestone now so
> that people can look at all the new features that we have. The number of
> projects nearly doubled since M2, because now it contains also the
> client UI code that we were planning for Riena.
> So we will publish a new M3 next week (thats the plan). It will contain
> as new
> - riena client ui code
> - a new concept called ridgets that we use for seperating views and
> controllers, abstracting from the UI toolkit in the controller, that
> includes the JFace databinding and some higher level APIs compared to
> the raw widget
> - its own navigation model with subapplications, modules,groups,
> submodulenodes
> - a concept to have different LookAndFeel for SWT applications
> independent from the application code itself together with two sample
> LnFs, but you can easily define your own Look and Feel.
> - many fixes and improvements (bugzilla fixes)
> - wizard support so that you can generate a hello application and the
> RCP Mail client as Riena Mail client so that its easier to understand
> how to use the various Riena APIs.
> We will have another milestone end of August which is when the original
> milestone was planned and that is then called M4.
> any questions ? dont hesitate to ask
> christian
Re: Milestone 1.0.0.M3 [message #6070 is a reply to message #6038] |
Thu, 03 July 2008 10:44 |
Christian Campo Messages: 597 Registered: July 2009 |
hi,
and I forgot to mention. We plan to have seperate downloads for win32 and mac os x. So Riena clients are running on Mac.
There are some small flaws in the Mac version but the Windows version isnt perfect. We are still incubation. So a lot is
still going on.
cheers
christian
> Hi Riena-users,
> as new
> the raw widget
> submodulenodes
> christian
Re: Milestone 1.0.0.M3 [message #6085 is a reply to message #6055] |
Thu, 03 July 2008 11:04 |
Ekke,
glad you like it.
I read your ObjectTransaction bug report again and (I apologize that havnt thought about this option before and) I think
you can already do it with the existing OT code. I wrote a reply in the bugzilla request so that we dont duplicate the
content in bugzilla and in the newsgroup.
Anyway I dont think there is more than we could do in our OT API. ???
let me know if that helps.....
christian
> application ;-)
> ekke
>> Hi Riena-users,
>> However we thought that it would be good to come up with some
>> milestone now so that people can look at all the new features that we
>> have. The number of projects nearly doubled since M2, because now it
>> contains also the client UI code that we were planning for Riena.
>> contain as new
>> the raw widget
>> submodulenodes
>> original milestone was planned and that is then called M4.
>> christian
Re: Milestone 1.0.0.M3 [message #6098 is a reply to message #6070] |
Thu, 03 July 2008 11:29 |
> hi,
good to hear - I need it
> still incubation. So a lot is still going on.
I'll give it a try
ekke
> cheers
> christian
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #6112 is a reply to message #6085] |
Thu, 03 July 2008 11:37 |
> Ekke,
> glad you like it.
> havnt thought about this option before and) I think you can already do
> that we dont duplicate the content in bugzilla and in the newsgroup.
I read your comment in bugzilla
so I can use it the usual way
perhaps I misunderstood your answer to my question if enums are
supported. (News 2005-05-20)
I didn't try it till now because I interpreted your answer as a no ;-)
at the moment I did only tested succesfully remoting :-)
and prepared things for ObjectTransactions
and had some trouble with P2, EasyBeans etc ...
but next week with M3 will be a good starting point to test the whole
workflow - I'll report
ekke
> christian
>> application ;-)
>> ekke
>>> Hi Riena-users,
>>> contain as new
>>> the raw widget
>>> submodulenodes
>>> christian
Re: Milestone 1.0.0.M3 [message #6124 is a reply to message #6038] |
Thu, 03 July 2008 12:21 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hi Christian,
I wanted to take a look at your ridget-implementation. Do you have a
project-set file people can use to fetch the sources with all
dependencies from CVS?
Tom
> Hi Riena-users,
> as new
> the raw widget
> submodulenodes
> christian
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: Milestone 1.0.0.M3 [message #6139 is a reply to message #6124] |
Thu, 03 July 2008 16:40 |
Hi Tom,
sure it called org.eclipse.riena.releng.....there are two project set files one for committers (the ssh piece) and the
pserver for non-committers. It checks out all the active Riena projects into your workspace.....
Let me know if you have questions.
christian
Tom Schindl schrieb:
> Hi Christian,
> Tom
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #6173 is a reply to message #6156] |
Thu, 03 July 2008 20:02 |
Hi tom,
maybe I am wrong here, but I believe concerning @Override you can mark overriden methods (methods also implemented in
the superclass) with @Override. I use Java 5 on Windows and on Mac (actually all Riena committer do) and we get no
compile errors. The difference in Java 6 is that you can also specify @Override for methods that you implement for an
interface. (I know there is also @Implements, not sure why there are two ways)
Concerning your stacktrace, I wonder what kind of target platform you specified. The Riena CVS version needs more than
there is in the Eclipse IDE (which is the default target platform). You basically need the complete equinox-SDK plus
the RCP-SDK as target platform. We supplied such a platform with the M2 milestone. How to set it up is described here
http://wiki.eclipse.org/Riena_Getting_started.
If you like to run the current CVS version, you could still use the M2 milestone as target platform and then checkout
the Riena cvs version. All Riena projects in the workspace will override the old versions in the target platform.
Sample.app.client is a relativly small sample. There is also the sample.app.mail.client and the example.client which
also contain more samples what a Riena client looks like.....
hope that helps
christian campo
> Hm,
> I can't launch the sample application on my OS-X-box. I get the error
> message below.
> By the way there are some compiler errors in
> org.eclipse.riena.example.client because you are using an @Override in
> the handlers which is not correct when compiling against Java5.
> Tom
>> !SESSION 2008-07-03 19:33:15.975
>> eclipse.buildId=unknown
>> java.version=1.5.0_13
>> java.vendor=Apple Computer, Inc.
>> BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=de_DE
>> Framework arguments: -application
>> org.eclipse.riena.example.client.application
>> Command-line arguments: -application
>> org.eclipse.riena.example.client.application -data
>> /Users/tomson/Documents/eclipse-ws/riena/../runtime-New_conf iguration
>> -dev
>> file:/Users/tomson/Documents/eclipse-ws/riena/.metadata/.plu gins/org.eclipse.pde.core/SWT
>> ExampleApplication/dev.properties -debug
>> /Users/tomson/Documents/eclipse-ws/riena/.metadata/.plugins/ org.eclipse.pde.core/SWT
>> ExampleApplication/.options -os macosx -ws carbon -arch x86
>> !ENTRY org.eclipse.osgi 4 0 2008-07-03 19:33:17.388
>> !MESSAGE An error occurred while automatically activating bundle
>> org.eclipse.ui.workbench (34).
>> !STACK 0
>> org.osgi.framework.BundleException: The activator
>> org.eclipse.ui.internal.WorkbenchPlugin for bundle
>> org.eclipse.ui.workbench is invalid
>> at
>> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:146)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleContextImpl.s tart(BundleContextImpl.java:980)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:346)
>> at
>> org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:265)
>> at
>> org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:400)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
>> at
>> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:427)
>> at
>> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:193)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:368)
>> at
>> org.eclipse.osgi.framework.internal.core.SingleSourcePackage .loadClass(SingleSourcePackage.java:33)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:441)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:397)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:385)
>> at
>> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:87)
>> at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
>> at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319 )
>> at java.lang.ClassLoader.defineClass1(Native Method)
>> at java.lang.ClassLoader.defineClass(ClassLoader.java:620)
>> at
>> org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.def ineClass(DefaultClassLoader.java:165)
>> at
>> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.defineC lass(ClasspathManager.java:554)
>> at
>> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findCla ssImpl(ClasspathManager.java:524)
>> at
>> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClassImpl(ClasspathManager.java:455)
>> at
>> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass_LockClassLoader(ClasspathManager.java:443)
>> at
>> org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:423)
>> at
>> at
>> at
>> org.eclipse.osgi.framework.internal.core.BundleLoader.findCl assInternal(BundleLoader.java:444)
>> at
>> at
>> at
>> at
>> org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:313)
>> at
>> org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
>> at
>> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:139)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1274)
>> at
>> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:160)
>> at
>> org.eclipse.core.internal.registry.ExtensionRegistry.createE xecutableExtension(ExtensionRegistry.java:867)
>> at
>> org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:243)
>> at
>> org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 51)
>> at
>> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:188)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:382)
>> at
>> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
>> at
>> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
>> at java.lang.reflect.Method.invoke(Method.java:585)
>> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
>> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
>> at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
>> at org.eclipse.equinox.launcher.Main.main(Main.java:1212)
>> Caused by: java.lang.NoClassDefFoundError: org/eclipse/swt/SWTError
>> at java.lang.Class.getDeclaredConstructors0(Native Method)
>> at java.lang.Class.privateGetDeclaredConstructors(Class.java:23 57)
>> at java.lang.Class.getConstructor0(Class.java:2671)
>> at java.lang.Class.newInstance0(Class.java:321)
>> at java.lang.Class.newInstance(Class.java:303)
>> at
>> org.eclipse.osgi.framework.internal.core.AbstractBundle.load BundleActivator(AbstractBundle.java:141)
>> ... 66 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !ENTRY org.eclipse.osgi 4 0 2008-07-03 19:33:17.395
>> org.eclipse.riena.navigation.ui.swt (27).
>> !STACK 0
>> org.eclipse.riena.internal.navigation.ui.swt.Activator for bundle
>> org.eclipse.riena.navigation.ui.swt is invalid
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> org/eclipse/ui/plugin/AbstractUIPlugin
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 33 more
>> Root exception:
>> java.lang.NoClassDefFoundError: org/eclipse/ui/plugin/AbstractUIPlugin
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !ENTRY org.eclipse.osgi 4 0 2008-07-03 19:33:17.430
>> !MESSAGE Application error
>> !STACK 1
>> org.eclipse.core.runtime.CoreException: Plug-in
>> org.eclipse.riena.example.client was unable to load class
>> org.eclipse.riena.example.client.application.SwtExampleAppli cation.
>> at
>> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .throwException(RegistryStrategyOSGI.java:180)
>> at
>> org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI .createExecutableExtension(RegistryStrategyOSGI.java:162)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter $TerminatingClassNotFoundException:
>> at
>> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:125)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 16 more
>> Caused by: org.osgi.framework.BundleException: The activator
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 28 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 33 more
> Tom
Re: Milestone 1.0.0.M3 [message #6193 is a reply to message #6173] |
Thu, 03 July 2008 20:03 |
And before I forget......Riena is based on the Eclipse 3.3. Equinox and RCP....
christian
> Hi tom,
> overriden methods (methods also implemented in the superclass) with
> committer do) and we get no compile errors. The difference in Java 6 is
> an interface. (I know there is also @Implements, not sure why there are
> two ways)
> specified. The Riena CVS version needs more than there is in the Eclipse
> hope that helps
> christian campo
>> Hm,
>> message below.
>> Tom
>>> -dev
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 66 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 33 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 16 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 28 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 33 more
>> Tom
Re: Milestone 1.0.0.M3 [message #6210 is a reply to message #6193] |
Fri, 04 July 2008 04:57 |
....and also runs under 3.4 Ganymde ;-)
http://ekkes-corner.blogspot.com/2008/06/eclipse-riena-getti ng-started-in.html
ekke
> RCP....
> christian
>> Hi tom,
>> for an interface. (I know there is also @Implements, not sure why
>> there are two ways)
>> hope that helps
>> christian campo
>>> Hm,
>>> message below.
>>> in the handlers which is not correct when compiling against Java5.
>>> Tom
>>>> -dev
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 66 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 33 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 16 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 28 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 33 more
>>> Tom
Re: Milestone 1.0.0.M3 [message #6226 is a reply to message #6210] |
Fri, 04 July 2008 08:19 |
Ekke,
I know you wrote a very nice blog entry how to run it under Equinox 3.4. However M3 is still out of the box based on
Equinox 3.3. M4 (the august version) will be based on Equinox 3.4 out of the box.....
christian
> ekke
>> and RCP....
>> christian
>>> Hi tom,
>>> mark overriden methods (methods also implemented in the superclass)
>>> Riena committer do) and we get no compile errors. The difference in
>>> implement for an interface. (I know there is also @Implements, not
>>> hope that helps
>>> christian campo
>>>> Hm,
>>>> error message below.
>>>> Tom
>>>>> -dev
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 66 more
>>>>> Root exception:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 33 more
>>>>> Root exception:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 16 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 28 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 33 more
>>>> Tom
Re: Milestone 1.0.0.M3 [message #6246 is a reply to message #6226] |
Fri, 04 July 2008 09:19 |
> Ekke,
> However M3 is still out of the box based on Equinox 3.3. M4
no problem ;-)
just wanted to give Tom Schindl a hint, that it also runs under Ganymde
if there'll be changes for M3 I'll report again
(the august
fine
ekke
> christian
>> ekke
>>> and RCP....
>>> christian
>>>> Hi tom,
>>>> you specified. The Riena CVS version needs more than there is in the
>>>> hope that helps
>>>> christian campo
>>>>> Hm,
>>>>> Tom
>>>>>> -dev
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 66 more
>>>>>> Root exception:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 33 more
>>>>>> Root exception:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> !STACK 1
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Caused by:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 16 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 28 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 33 more
>>>>> Tom
Re: Milestone 1.0.0.M3 [message #6261 is a reply to message #6038] |
Fri, 04 July 2008 14:10 |
david leloup Messages: 36 Registered: July 2009 |
Member |
hi,
excuse my question but i'd like to know what is ui specific about riena
is it aimed to replace rcp in a riena context ??
i browsed the code in cvs and saw some application and navigation node
classes
can you explain a bit please
thanks
David
"Christian Campo" <christian.campo@compeople.de> wrote in message
news:g4i8a8$3o0$1@build.eclipse.org...
> Hi Riena-users,
> projects nearly doubled since M2, because now it contains also the client
> So we will publish a new M3 next week (thats the plan). It will contain as
> new
> includes the JFace databinding and some higher level APIs compared to the
> raw widget
> submodulenodes
> - wizard support so that you can generate a hello application and the RCP
> Mail client as Riena Mail client so that its easier to understand how to
> christian
Re: Milestone 1.0.0.M3 [message #6275 is a reply to message #6261] |
Sat, 05 July 2008 18:37 |
Hi David,
did you read the Riena proposal ? http://www.eclipse.org/proposals/riena/
It explains the goals of Riena.
In the UI we dont replace RCP but extend it. There are certain issues that are not yet either addressed by RCP or that
RCP does different. RCP applications a lot of the times look very similar to the Eclipse IDE. Riena is more focused not
on the requirements of developers but endusers. So less flexibility, a clearer concept for navigation (not 10 ways to
achieve the same result)
So we reuse a lot of things RCP but they look a little different. We have views, actions, and all the SWT stuff. We use
perspectives to model subapplications.
There was a presentation at EclipseCon 2008 http://www.eclipsecon.org/2008/index.php?page=sub/&id=15 0 that you probably
missed that in its presentation slides explains some aspects of what we want to change in the UI.
Any further questions ? let me know
christian
david schrieb:
> hi,
> classes
> thanks
> David
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #6310 is a reply to message #6275] |
Fri, 25 July 2008 07:26 |
Member |
hi Christian,
thanks for your reply.
it's clearer now
news:486FBF7B.6030006@compeople.de...
> Hi David,
> are not yet either addressed by RCP or that RCP does different. RCP
> Riena is more focused not on the requirements of developers but endusers.
> views, actions, and all the SWT stuff. We use perspectives to model
> subapplications.
> probably missed that in its presentation slides explains some aspects of
> christian
> david schrieb:
>> hi,
>> classes
>> thanks
>> David
>>> Hi Riena-users,
>>> as new
>>> the raw widget
>>> submodulenodes
>>> christian
Re: Milestone 1.0.0.M3 [message #572468 is a reply to message #6038] |
application ;-)
ekke
> Hi Riena-users,
> as new
> the raw widget
> submodulenodes
> christian
Re: Milestone 1.0.0.M3 [message #572492 is a reply to message #6038] |
hi,
still going on.
cheers
christian
> Hi Riena-users,
> as new
> the raw widget
> submodulenodes
> christian
Re: Milestone 1.0.0.M3 [message #572515 is a reply to message #6055] |
Ekke,
glad you like it.
christian
> application ;-)
> ekke
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #572583 is a reply to message #6070] |
> hi,
I'll give it a try
ekke
> cheers
> christian
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #572636 is a reply to message #6085] |
> Ekke,
> glad you like it.
ekke
> christian
>> application ;-)
>> ekke
>>> Hi Riena-users,
>>> contain as new
>>> the raw widget
>>> submodulenodes
>>> christian
Re: Milestone 1.0.0.M3 [message #572668 is a reply to message #6038] |
Hi Christian,
Tom
> Hi Riena-users,
> as new
> the raw widget
> submodulenodes
> christian
Re: Milestone 1.0.0.M3 [message #572692 is a reply to message #6124] |
Hi Tom,
christian
> Hi Christian,
> Tom
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #572728 is a reply to message #6156] |
Hi tom,
hope that helps
christian campo
> Hm,
> message below.
> Tom
>> -dev
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 66 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 0
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 33 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> !STACK 1
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> Caused by:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 16 more
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 28 more
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 33 more
> Tom
Re: Milestone 1.0.0.M3 [message #572742 is a reply to message #6173] |
christian
> Hi tom,
> two ways)
> hope that helps
> christian campo
>> Hm,
>> message below.
>> Tom
>>> -dev
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 66 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 33 more
>>> Root exception:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> !STACK 1
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> Caused by:
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 16 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 28 more
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> ... 33 more
>> Tom
Re: Milestone 1.0.0.M3 [message #572789 is a reply to message #6193] |
ekke
> RCP....
> christian
>> Hi tom,
>> there are two ways)
>> hope that helps
>> christian campo
>>> Hm,
>>> message below.
>>> Tom
>>>> -dev
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 66 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 0
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 33 more
>>>> Root exception:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> !STACK 1
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Caused by:
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 16 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 28 more
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> ... 33 more
>>> Tom
Re: Milestone 1.0.0.M3 [message #572819 is a reply to message #6210] |
Ekke,
christian
> ekke
>> and RCP....
>> christian
>>> Hi tom,
>>> hope that helps
>>> christian campo
>>>> Hm,
>>>> Tom
>>>>> -dev
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 66 more
>>>>> Root exception:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 0
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 33 more
>>>>> Root exception:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> !STACK 1
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> Caused by:
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 16 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 28 more
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> at
>>>>> ... 33 more
>>>> Tom
Re: Milestone 1.0.0.M3 [message #572864 is a reply to message #6226] |
> Ekke,
no problem ;-)
(the august
fine
ekke
> christian
>> ekke
>>> and RCP....
>>> christian
>>>> Hi tom,
>>>> hope that helps
>>>> christian campo
>>>>> Hm,
>>>>> Tom
>>>>>> -dev
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 66 more
>>>>>> Root exception:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> !STACK 0
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 33 more
>>>>>> Root exception:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> !STACK 1
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> Caused by:
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 16 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 28 more
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> at
>>>>>> ... 33 more
>>>>> Tom
Re: Milestone 1.0.0.M3 [message #572891 is a reply to message #6038] |
Member |
hi,
classes
thanks
David
> Hi Riena-users,
> new
> raw widget
> submodulenodes
> christian
Re: Milestone 1.0.0.M3 [message #572922 is a reply to message #6261] |
Hi David,
christian
david schrieb:
> hi,
> classes
> thanks
> David
>> Hi Riena-users,
>> contain as new
>> the raw widget
>> submodulenodes
>> christian
Re: Milestone 1.0.0.M3 [message #573009 is a reply to message #6275] |
Member |
hi Christian,
it's clearer now
> Hi David,
> subapplications.
> christian
> david schrieb:
>> hi,
>> classes
>> thanks
>> David
>>> Hi Riena-users,
>>> as new
>>> the raw widget
>>> submodulenodes
>>> christian
Current Time: Fri Sep 20 00:41:16 GMT 2024
Powered by FUDForum. Page generated in 0.08184 seconds
