Home » Archived » XML Schema Definition (XSD) » XSDImporter.java cannot run headless
XSDImporter.java cannot run headless [message #67978] |
Thu, 27 April 2006 03:24 |
Scott Hendrickson Messages: 69 Registered: July 2009 |
Member |
When converting XSD to ECore headless, I would get a
NullPointerException in XSDImporter.java when there were errors or
warnings in my schema:
Exception in thread "main" java.lang.NullPointerException at
org.eclipse.xsd.ecore.importer.XSDImporter.doComputeEPackage s(XSDImporter.java:142)
This was because it was trying to get the plugin instance, which is null
when running headless. Below is a patch to use a plugin id directly
"org.eclipse.xsd.ecore.importer". This seems to coincide with the
OK_INSTANCE and CANCEL_INSTANCE in Diagnostic.java.
Could this patch be applied?
-- Scott
### Eclipse Workspace Patch 1.0
#P org.eclipse.xsd.ecore.importer
Index: src/org/eclipse/xsd/ecore/importer/XSDImporter.java
RCS file:
/cvsroot/tools/org.eclipse.xsd/plugins/org.eclipse.xsd.ecore .importer/src/org/eclipse/xsd/ecore/importer/XSDImporter.jav a,v
retrieving revision 1.8
diff -u -r1.8 XSDImporter.java
--- src/org/eclipse/xsd/ecore/importer/XSDImporter.java 14 Dec 2005
08:00:01 -0000 1.8
+++ src/org/eclipse/xsd/ecore/importer/XSDImporter.java 27 Apr 2006
03:14:12 -0000
@@ -139,7 +139,7 @@
List information = (List)i.next();
diagnostic.add(new BasicDiagnostic(
"error".equals(information.get(0)) ? Diagnostic.ERROR :
"warning".equals(information.get(0)) ? Diagnostic.WARNING : Diagnostic.INFO,
- XSDImporterPlugin.getPlugin().getBundle().getSymbolicName(),
+ "org.eclipse.xsd.ecore.importer",
0,
(String)information.get(1),
null));
Re: XSDImporter.java cannot run headless [message #68000 is a reply to message #67978] |
Thu, 27 April 2006 10:08 |
Scott,
I'm confused. The plugin instances should work properly, i.e., not be
null, when running headless, since plugin initialization will work the
same way as running in the GUI. Are you mixing up headless verses
standalone? The former involves running a registered application and
the later involves invoking directly from a main().
> null when running headless. Below is a patch to use a plugin id
> directly "org.eclipse.xsd.ecore.importer". This seems to coincide with
> the OK_INSTANCE and CANCEL_INSTANCE in Diagnostic.java.
> -- Scott
> RCS file:
> 08:00:01 -0000 1.8
> 03:14:12 -0000
> @@ -139,7 +139,7 @@
> Diagnostic.INFO,
> 0,
> null));
Re: XSDImporter.java cannot run headless [message #68021 is a reply to message #68000] |
Thu, 27 April 2006 16:56 |
Member |
Yes, you are right. I meant standalone. So, I guess this leads me to the
following question. Is this intended to run standalone? Or, must I
create an application to run the importer.
Thank you,
-- Scott
Ed Merks wrote:
> Scott,
>> Thanks,
>> -- Scott
>> RCS file:
>> 08:00:01 -0000 1.8
>> 03:14:12 -0000
>> @@ -139,7 +139,7 @@
>> Diagnostic.INFO,
>> 0,
>> null));
Re: XSDImporter.java cannot run headless [message #68042 is a reply to message #68021] |
Thu, 27 April 2006 17:45 |
Scott,
I was just talking with Marcelo about this. The importer framework was
not designed to run standalone, because none of the generator stuff
worked standalone at the time the importer was designed. But in the EMF
2.2 development cycle we've made all kinds of changes so that in fact
GenModel and the generation support in general can run standalone. So
we'd like to make the importer framework work standalone too (as the new
exporter framework does), but now that we're in the RC shutdown phase,
we simply can't make all the necessary changes. If you open a feature
request, we can try to provide this support during the next cycle.
> the following question. Is this intended to run standalone? Or, must I
> Thank you,
> -- Scott
> Ed Merks wrote:
>> Scott,
>> be null, when running headless, since plugin initialization will work
>> the same way as running in the GUI. Are you mixing up headless
>> verses standalone? The former involves running a registered
>> application and the later involves invoking directly from a main().
>>> with the OK_INSTANCE and CANCEL_INSTANCE in Diagnostic.java.
>>> Thanks,
>>> -- Scott
>>> RCS file:
>>> 2005 08:00:01 -0000 1.8
>>> 2006 03:14:12 -0000
>>> @@ -139,7 +139,7 @@
>>> : "warning".equals(information.get(0)) ? Diagnostic.WARNING :
>>> Diagnostic.INFO,
>>> 0,
>>> null));
Re: XSDImporter.java cannot run headless [message #68061 is a reply to message #68042] |
Thu, 27 April 2006 21:28 |
Member |
Thanks Ed for setting me straight on the terminology. I'm glad to hear
that this is a possibility for a future version. I'll go ahead and open
up a feature request.
-- Scott
Ed Merks wrote:
> Scott,
>> Thank you,
>> -- Scott
>> Ed Merks wrote:
>>> Scott,
>>>> Thanks,
>>>> -- Scott
>>>> RCS file:
>>>> 2006 03:14:12 -0000
>>>> @@ -139,7 +139,7 @@
>>>> Diagnostic.INFO,
>>>> 0,
>>>> null));
Re: XSDImporter.java cannot run headless [message #598042 is a reply to message #67978] |
Ed Merks Messages: 33142 Registered: July 2009 |
Scott,
> -- Scott
> RCS file:
> 08:00:01 -0000 1.8
> 03:14:12 -0000
> @@ -139,7 +139,7 @@
> Diagnostic.INFO,
> 0,
> null));
Ed Merks
Re: XSDImporter.java cannot run headless [message #598047 is a reply to message #68000] |
Member |
Thank you,
-- Scott
Ed Merks wrote:
> Scott,
>> Thanks,
>> -- Scott
>> RCS file:
>> 08:00:01 -0000 1.8
>> 03:14:12 -0000
>> @@ -139,7 +139,7 @@
>> Diagnostic.INFO,
>> 0,
>> null));
Re: XSDImporter.java cannot run headless [message #598055 is a reply to message #68021] |
Scott,
> Thank you,
> -- Scott
> Ed Merks wrote:
>> Scott,
>>> Thanks,
>>> -- Scott
>>> RCS file:
>>> 2006 03:14:12 -0000
>>> @@ -139,7 +139,7 @@
>>> Diagnostic.INFO,
>>> 0,
>>> null));
Ed Merks
Re: XSDImporter.java cannot run headless [message #598061 is a reply to message #68042] |
Member |
-- Scott
Ed Merks wrote:
> Scott,
>> Thank you,
>> -- Scott
>> Ed Merks wrote:
>>> Scott,
>>>> Thanks,
>>>> -- Scott
>>>> RCS file:
>>>> 2006 03:14:12 -0000
>>>> @@ -139,7 +139,7 @@
>>>> Diagnostic.INFO,
>>>> 0,
>>>> null));
Current Time: Fri Apr 26 14:06:28 GMT 2024
Powered by FUDForum. Page generated in 0.03906 seconds
