** Indigo java.binaries / dependency issue [message #676925] |
Tue, 07 June 2011 01:32 |
Miles Parker Messages: 1341 Registered: July 2009 |
Hi guys,
I'm almost tempted to put "HELP!!" " in the subject line, ala those "this is really important because my homework is due tomorrow" messages, but this is really important because my release is due tomorrow and naturally something new just broke. I've started getting:
INFO: perform '--properties' '/opt/users/hudsonbuild/workspace/amp-nightly/buildroot/build.properties' '-Dbuckminster.reference.repository=https://hudson.eclipse.org/hudson/job/amp-nightly/lastSuccessfulBuild/artifact/amp.p2.repository/' 'org.eclipse.amp.build#build'
CSpec org.apache.lucene:osgi.bundle$2.9.1.v201101211721 has no action, group, or local artifact named java.binaries
From earlier traffic on cross-projects list, I understand that this can be a signal that there is a dependency issue somewhere? I found such an issue -- I'm depending on birt datatools which has a dependency on org.apache.lucene 1.9.1, while everyone else in the Eclipse universe is using 2.9.1. I've got an email to them asking them to update to 2.9 if at all possible but can you confirm that this kind of whole number difference could be the cause of the issue? If so is there any other recourse if I can't get BIRT to change dependency versioining?
thanks!
Miles
[Updated on: Tue, 07 June 2011 01:33] Report message to a moderator
FUDForum. Page generated in 0.03685 seconds
