Re: Enter Parameters popup form [message #676878 is a reply to message #676792] |
Mon, 06 June 2011 19:13 |
Teo,
The parameter page is defined using jsp/js files in the webcontent
directory of the viewer. Take a look at:
webcontent\birt\ajax\ui\dialog\BirtParameterDialog.js
and
webcontent\birt\pages\dialog\ParameterDialogFragment.jsp
Jason
> I would like to know if it is possible to change the layout of the popup
> window that BIRT uses for entering parameters. I have a big load of
> parameters to set for extracting my reports and the existing format of
> the popup window is not very convenient. Are there some libraries that I
> can use that will enable me making moderations on the Enter Parameters
> popup window or do I need to build a new user interface from scratch?
> Thank you for you help
> -Teo
Re: Enter Parameters popup form [message #677049 is a reply to message #676878] |
Tue, 07 June 2011 12:14 |
Teo Messages: 14 Registered: May 2011 |
Hi Jason,
first of all thank you for you quick response. I took a look at the files you suggested. I was wondering if it possible to create a set of checkbox parameters that are pulled dynamically from a dataset as in the case of a list box. With the existing parameter setting framework of BIRT I do not believe that it is possible. Do you have any idea how this could be implemented?
thanks again for your help
Teo
[Updated on: Tue, 07 June 2011 12:29] Report message to a moderator
Re: Enter Parameters popup form [message #677191 is a reply to message #677049] |
Tue, 07 June 2011 17:00 |
Teo,
One way you could do something similar to this is to create one report
that will act as a driver to another report. In the initial report you
could use a text element that is nested in a table bound to your dataset
that creates a html check box for each row of the dataset. You could
then add a submit button to the text element that would forward the
checkbox values to the second report.
Jason
On 6/7/2011 8:14 AM, Teo wrote:
> Hi Jason,
> Teo
FUDForum. Page generated in 0.03421 seconds
