Home » Eclipse Projects » Rich Client Platform (RCP) » Editors tab order + menu text
Editors tab order + menu text [message #676687] Mon, 06 June 2011 03:06 Go to next message
Hello!
The method IWorkbenchPage.getEditorReferences() returns the array of open editors but not in an order of their tabs oder (for instance when I change this order manually by mouse).
How to get the information of the editors tab order?
Thank you.
[Updated on: Tue, 07 June 2011 07:43] by Moderator
Re: Editors tab order [message #676778 is a reply to message #676687] Mon, 06 June 2011 10:11 Go to previous messageGo to next message
There's no way to get the editors in tab order in Eclipse 3.x. That information is buried in the implementation details of the default presentation: org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.getPartList()
In Eclipse 4.1, the model contains the editor references in tab order.
PW
Re: Editors tab order [message #677036 is a reply to message #676778] Tue, 07 June 2011 07:32 Go to previous messageGo to next message
Thank you for answer! I am waiting for Eclipse 4.1 Smile.
Also one question...
The text or image of a menu item (created as a commands) can be updated in updateElement() method in IElementUpdater interface implemented in handler of a command based on AbstractHandler class. But how to update the menu text which contains such item? The way similar to update the item text don't work...
[Updated on: Tue, 07 June 2011 07:41] by Moderator
Re: Editors tab order [message #677052 is a reply to message #677036] Tue, 07 June 2011 08:18 Go to previous messageGo to next message
ALGROM wrote on Tue, 07 June 2011 07:32
Yes, that's true.
You mean how do you update the containing Menu? There is no API for that.
PW
Re: Editors tab order [message #677059 is a reply to message #677052] Tue, 07 June 2011 08:37 Go to previous message
Text of menu items (as commands) can be updated in the updateElement() method implemented into the handler of a command. Menus (not items, such as "File", "Edit" etc.) has no command but I need to update their texts programmically too...
Which is the right way. Of course, I can do it directly via the MenuMeneger but I think it is not right way in RCP.
[Updated on: Wed, 08 June 2011 03:27] by Moderator
Previous Topic:Only one instance of my RCP product
Next Topic:auto saving preferences
Current Time: Wed Nov 05 12:28:29 EST 2025
Powered by FUDForum. Page generated in 0.05250 seconds
