Determine Visibility of a Row in Script [message #676260] |
Fri, 03 June 2011 12:49 |
No real name Messages: 4 Registered: May 2011 |
Junior Member |
I am working on a customizable report in which vendor information is listed, each vendor can have up to 4 rows of data, with a blank row between each vendor. But it is customizable by the user, so it can have 1, 2, 3, or 4 rows of data per vendor. I want to highlight every other row Silver for easier readability. I originally had this code with a variable j = 0 set up once in the beforeFactory.
//this toggles between silver and white, every other line - in the "onCreate" script for each row
if (j == 0 ){
this.getStyle().backgroundColor = "Silver";
j = 1;
else j = 0;
The problem with this is that not all rows are visible so if I evaluate the following rows as the following colors:
1 Silver
2 White
3 Silver
4 White
5 Silver (blank space row)
Then, if only one row is selected to show by the user, it will be silver, and the blank row will be silver as well, giving an all silver report! I therefore want to know how to get a variable from the particular row that tells me whether its visibility rules evaluated to true or false. I have been researching some solutions and looking at the API and based on what I found, tried the following in the onCreate script for the first detail row:
TableHandle th = (TableHandle)reportContext.getDesignHandle().findElement("vendorMasterTable");
RowHandle rowHandle = (RowHandle)th.getDetail().get(0);
Iterator it = rowHandle.visibilityRulesIterator();
// and then somehow go through the rules and make sure they're all true before toggling the silver and white
The first line gives me a compile error: "missing ; before statement" and there's nothing before it! I'm not sure if this code doesn't go in the onCreate script of the row or if I need to import something, and after much research, I can't figure it out. I am pretty new to BIRT scripting so I may just be missing something that's obvious to you experts.
Meredith
Re: Determine Visibility of a Row in Script [message #676277 is a reply to message #676260] |
Fri, 03 June 2011 13:46 |
Meridith,
You are putting Java code in script which will not work. You can call
Java code from the script but your code will need to be modified:
for example, this:
TableHandle th =
to
var th = reportContext.getDesignHandle().findElement("vendorMasterTable");
An easier way of doing what you need is to use the
this.getStyle().visibleFormat property in the onCreate script. I wrote
up a quick example on this located here:
http://www.birt-exchange.org/org/devshare/designing-birt-reports/1370-alternating-colors-with-hidden-rows/
Essentially just add this script to your onCreate of the detail row:
if( typeof jj == 'undefined' ){
jj=0;
if( (this.getStyle().visibleFormat != "all") ){
if( jj !=0 ){
this.getStyle().backgroundColor="Silver";
jj=0;
}else{
jj++;
Jason
On 6/3/2011 8:49 AM, forums-noreply@eclipse.org wrote:
> Hello,
> if (j == 0 ){ this.getStyle().backgroundColor = "Silver";
> j = 1;
> else j = 0;
> 1 Silver
> 2 White
> 3 Silver
> 4 White
> TableHandle th =
> Meredith
FUDForum. Page generated in 0.03112 seconds
