Re: How do I create a Diagram from an existing UML model [message #709706 is a reply to message #707989] |
Thu, 04 August 2011 07:57 |
Yann Tanguy Messages: 80 Registered: July 2009 |
Member |
The editor may be blank because no diagram have been created yet.
First (after opening the di file) switch to Papyrus perspective, the "ModelExplorer" should appears on the left side of your eclipse.
Try to select a Package and to create a Class Diagram (right-click on the Package element in explorer and select "/New Diagram/Create a new Class Diagram" command).
A Class Diagram should be created and its editor should open. Did this work ?
Then you can manually populate the diagram with elements from your model by dragging them in the ModelExplorer and dropping them in the diagram editor.
[Updated on: Thu, 04 August 2011 08:21] Report message to a moderator
FUDForum. Page generated in 0.03512 seconds
