Home » Modeling » Graphiti » Pictogram Element Not updating after DirectEdit
Pictogram Element Not updating after DirectEdit [message #676190] Fri, 03 June 2011 02:44 Go to next message
I have a pretty complicated pictogram hierarchy with nested container shapes and shapes. I have a editable 'Text' in one of the shapes. When the 'DirectEditingFeature' is called on the pictogram element, though the domain model is setting the right values, the pictogram element is not refreshed.
However when I redraw the main parent(layouting), everything is updated. Does anybody have any ideas on this? I see in the tutorial that after the name is edited for EClass upon create, a call is made to update its parent (updatePictogramElement(((Shape) pe).getContainer())). Do I have to call updation of all the parent containers to get my text updated ? [Tried that, but still no result]
Thanks in advance for help.
Murthy
Re: Pictogram Element Not updating after DirectEdit [message #676217 is a reply to message #676190] Fri, 03 June 2011 05:05 Go to previous messageGo to next message
Hi. You should check your update features. What shapes are they responsible for?
After editing the domain model you have to call an update (updatePictogramElement(PictogramElement pe)) of the pictogram element you have an update feature registered for. Best regards, Christian
Re: Pictogram Element Not updating after DirectEdit [message #676229 is a reply to message #676217] Fri, 03 June 2011 06:00 Go to previous messageGo to next message
Hello Christian,
Thanks for your suggestion.
I have already called updatePictogramElement for the pictogram element the domain model is linked with and for which the update feature was registered. When i debug more, I also find that the graphicsAlgorithm for the pictogram has been updated with the new value, but the editor in the screen still shows the old value. Any ideas/thoughts ?
Murthy
Re: Pictogram Element Not updating after DirectEdit [message #676735 is a reply to message #676229] Mon, 06 June 2011 07:23 Go to previous messageGo to next message
Don't know exactly whats the reason, but just found a workable solution. Not a pretty one, but it works for me.
After the direct edit is done for a text control within nested shapes and containers, I update the main (root)pictogram element. Also after updating I call the layoutElement method and every thing works fine. The snippet which i use is as below.
		//The pictogram element that is being updated
		updatePictogramElement(((Shape) pe));
		//My Root container
		ContainerShape container = ((Shape) pe).getContainer().getContainer().getContainer();
		//Just increase the 'Y' co-ordinate of the graphical algorithm so that layout is called
		container.getGraphicsAlgorithm().setY(container.getGraphicsAlgorithm().getY()+1);
		//Call Layout
		layoutPictogramElement(container);
Kindly someone let me know if there exists a better solution to this.
Murthy
Re: Pictogram Element Not updating after DirectEdit [message #691838 is a reply to message #676190] Sat, 02 July 2011 10:26 Go to previous messageGo to next message
Again using a topic for a similar problem: I created and added a Connection to the diagram between two Classes. The Connection is initially labeled with a text. This works fine. Furthermore I created a DirectEditingFeature for the Connection and a ConnectionFilter and a ConnectionSection for the property view of my Connection. This also works fine, the value of the label is shown in the properties view and it can be changed. I use a FocusListener and an UpdateFeature to refresh the pictogramElement of the Connection but this doesn't work.
Interestingly the directEdit or the edit in the properties view is executed: Wenn I click on the label of the Connection or the Connection itself, the current labelText is shown in my properties view and when I change the labelText via properties view or via the directEdit, the new labelText is saved. When I click on the label or the Connection again, the new labelText is shown in my properties view. When I click on the label, so that the text can be directly edited, the editable textField shows the new labelText. But when I confirm the change of the textLabel, the old textLabel is shown on the diagram. However the new labelText is shown in the properties view.
I'm a bit confused about the behavior of my diagram. Any common mistakes I made?
Maybe I'm not quite familiar with Connections and ConnectionDecorators: How does Graphiti handle the connection of these two elements? How is the change of one element recognized by the other element?
Thanks for your reply.
Re: Pictogram Element Not updating after DirectEdit [message #692378 is a reply to message #691838] Mon, 04 July 2011 06:23 Go to previous message
This sounds as if your update feature is not correctly working. Either is
does not recognize the changed value or the actual update does not work
correctly.
In general ConnectionDecorators are children of Connections. Usually you
would link a Connection to a business object, as soon as that changes a
corresponding update feature for that BO is searched. That would then need
to update both the Connection and ConnectionDecorator.
There's also a section on editable property sheets in our FAQ:
http://www.eclipse.org/graphiti/developers/faq.php . Maybe that helps.
Michael
"Kalle" schrieb im Newsbeitrag news:iun98v$vko$1@news.eclipse.org...
this doesn't work.
made?
Previous Topic:Connections anchored to Connections?
Next Topic:Convenient direct editing
Current Time: Tue Oct 28 18:37:49 EDT 2025
Powered by FUDForum. Page generated in 0.26747 seconds
