Home » Archived » BIRT » Empty PDF report downloaded as attachment from BIRT enabled web application
Empty PDF report downloaded as attachment from BIRT enabled web application [message #676064] |
Thu, 02 June 2011 16:51 |
Originally posted by: msotomayor
Hello:
I built a web application that uses the RE API to generate reports as
PDF files. The web application generates the report correctly but saves
it in another file.
I need the web application to ask the user for the location were to
download the file. However, when the user specifies the file name to
use and the desired location, the browser actually creates two files.
The file the user wants is created empty and the file with the actual
report contents is created in the home folder named as "report.pdf".
I'm using the following code to tell the browser to download the file as
an attachment:
String headerValue =
String.format( "attachment; filename=%s", reportFileName);
response.setHeader( "Content-Disposition", headerValue );
response.setContentType( "application/pdf" );
I'm I missing something?
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676065 is a reply to message #676064] |
Thu, 02 June 2011 16:58 |
I have done it like:
resp.setContentType( "application/pdf" );
resp.setHeader ("Content-Disposition","inline; filename=test.pdf");
and in the PDFRenderOption I put:
options.setOutputStream(resp.getOutputStream());
Jason
On 6/2/2011 12:51 PM, msotomayor wrote:
> Hello:
> it in another file.
> download the file. However, when the user specifies the file name to use
> and the desired location, the browser actually creates two files. The
> file the user wants is created empty and the file with the actual report
> an attachment:
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676090 is a reply to message #676065] |
Thu, 02 June 2011 19:08 |
Hi Jason:
Thank you for replying.
That certainly works, but the call:
causes the document to open within the browser.
What I really need is the browser to open the save as dialog without
displaying the contents of the report. If I comment that call, the
dialog is opened but the two files are created, the desired by the user
empty and another one called "report.pdf" with the actual contents.
Any other ideas?
> Jason
>> Hello:
>> it in another file.
>> an attachment:
>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676117 is a reply to message #676090] |
Thu, 02 June 2011 20:18 |
Put that line back in ad change the content disposition to use attachment.
resp.setHeader("Content-disposition","attachment; filename=\""
+"test.pdf" +"\"");
Jason
On 6/2/2011 3:08 PM, msotomayor wrote:
> Hi Jason:
> Any other ideas?
>> Jason
>>> Hello:
>>> it in another file.
>>> an attachment:
>>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676118 is a reply to message #676117] |
Thu, 02 June 2011 21:14 |
Thanks again, but it didn't worked neither.
Should I use a ByteArrayOutputStream?
> +"test.pdf" +"\"");
> Jason
>> Hi Jason:
>> Any other ideas?
>>> Jason
>>>> Hello:
>>>> it in another file.
>>>> use
>>>> report
>>>> file as
>>>> an attachment:
>>>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676270 is a reply to message #676118] |
Fri, 03 June 2011 13:04 |
I just tried this and it worked for me. Where is it dropping the second
file?
Jason
>> attachment.
>> +"test.pdf" +"\"");
>> Jason
>>> Hi Jason:
>>> Any other ideas?
>>>> Jason
>>>>> Hello:
>>>>> saves
>>>>> it in another file.
>>>>> use
>>>>> report
>>>>> file as
>>>>> an attachment:
>>>>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676312 is a reply to message #676270] |
Fri, 03 June 2011 15:31 |
The second file (which contains the actual contents of the report) is
automatically named as "report.pdf" and is dropped at the user's home
folder. I noticed that this file is created before the one that the
user specifies in the save as dialog.
> file?
> Jason
>>> attachment.
>>> +"test.pdf" +"\"");
>>> Jason
>>>> Hi Jason:
>>>> Any other ideas?
>>>>> Jason
>>>>>> Hello:
>>>>>> saves
>>>>>> it in another file.
>>>>>> use
>>>>>> report
>>>>>> file as
>>>>>> an attachment:
>>>>>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676314 is a reply to message #676312] |
Fri, 03 June 2011 15:46 |
The file gets created even if you use this line?
Jason
> folder. I noticed that this file is created before the one that the user
>> file?
>> Jason
>>>> attachment.
>>>> +"test.pdf" +"\"");
>>>> Jason
>>>>> Hi Jason:
>>>>> user
>>>>> Any other ideas?
>>>>>> Jason
>>>>>>> Hello:
>>>>>>> reports as
>>>>>>> saves
>>>>>>> it in another file.
>>>>>>> use
>>>>>>> The
>>>>>>> report
>>>>>>> file as
>>>>>>> an attachment:
>>>>>>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676342 is a reply to message #676314] |
Fri, 03 June 2011 19:51 |
I found the solution. The HttpServletResponse headers MUST be set
before setting the render options not the opposite.
This is what I have now. I commented some observations along the code.
response.setContentType( mimeType );
String headerValue = "attachment; filename=" + reportFileName;
IRenderOption renderOption = new PDFRenderOption();
renderOption.setOutputFormat( IRenderOption.OUTPUT_FORMAT_PDF );
renderOption.setSupportedImageFormats( "JPG;PNG;BMP;SVG;GIF" );
renderOption.setOutputStream( response.getOutputStream() );
// * Downloads file automatically
// renderOption.setOutputFileName( reportFileName );
task.setRenderOption( renderOption );
task.run();
BTW, the code is part of a Spring MVC webapp ran by Tomcat. I was
testing the code with Google Chrome and Firefox on Linux Fedora 14 with
the acroread package installed.
Hope this can help somebody. Thank you very much for your help!
> Jason
>>> file?
>>> Jason
>>>>> attachment.
>>>>> +"test.pdf" +"\"");
>>>>> Jason
>>>>>> Hi Jason:
>>>>>> user
>>>>>> Any other ideas?
>>>>>>> Jason
>>>>>>>> Hello:
>>>>>>>> reports as
>>>>>>>> saves
>>>>>>>> it in another file.
>>>>>>>> name to
>>>>>>>> use
>>>>>>>> The
>>>>>>>> report
>>>>>>>> file as
>>>>>>>> an attachment:
>>>>>>>> Thanks,
Re: Empty PDF report downloaded as attachment from BIRT enabled web application [message #676348 is a reply to message #676342] |
Fri, 03 June 2011 20:30 |
Thanks for the update.
Jason
On 6/3/2011 3:51 PM, ms wrote:
> I found the solution. The HttpServletResponse headers MUST be set before
> task.run();
>> Jason
>>>> file?
>>>> Jason
>>>>>> attachment.
>>>>>> +"test.pdf" +"\"");
>>>>>> Jason
>>>>>>> Hi Jason:
>>>>>>> user
>>>>>>> Any other ideas?
>>>>>>>> Jason
>>>>>>>>> Hello:
>>>>>>>>> reports as
>>>>>>>>> saves
>>>>>>>>> it in another file.
>>>>>>>>> were to
>>>>>>>>> name to
>>>>>>>>> use
>>>>>>>>> The
>>>>>>>>> report
>>>>>>>>> file as
>>>>>>>>> an attachment:
>>>>>>>>> Thanks,
Current Time: Sat May 11 01:09:05 GMT 2024
Powered by FUDForum. Page generated in 0.04491 seconds
