Home » Eclipse Projects » Plugin Development Environment (PDE) » Building two features from one build.xml file
Building two features from one build.xml file [message #675999] Thu, 02 June 2011 06:41 Go to next message
I have build.xml file (attached).
It builds feature com.mybuild1. I can clearly state it in tag <property name="topLevelElementId" value="com.mybuild1" />
A zip archive is created with feature/com.mybuild1 and plugins/com.mybuild1.tade.
The script is executed via antRunner application through Eclipse.
My question is how I can modify my build.xml file to be able to build several features and plug-ins?
For example, I can copy to ${buildDirectory} other features and plug-ins.
As I correctly understand topLevelElementId specifies the feature ID it will build.
Is there any way to do build of all features in one build.xml file?
Any help and refernces to articles are welcome.
Thanks in advance,
Vasily.
  • Attachment: build.xml
    (Size: 1.26KB, Downloaded 257 times)
Re: Building two features from one build.xml file [message #676741 is a reply to message #675999] Mon, 06 June 2011 07:47 Go to previous message
the plugins/org.eclipse.pde.build_3.7.0.v20110418/templates/headless-build/allElements.xml template should help. Declare all the features to be build in this file. The comments describe how to.
Previous Topic:Generate "Ant build file" outside Eclipse
Next Topic:disabling plug-in on workspace / runtime start
Current Time: Mon Oct 27 14:05:57 EDT 2025
Powered by FUDForum. Page generated in 0.06578 seconds
