Re: [EMF.Edit] removeCommand [message #675479 is a reply to message #675409] |
Tue, 31 May 2011 16:24 |
smaoui asma Messages: 50 Registered: July 2009 Location: Paris Saclay, France |
Member |
The problem comes from the fact that the node to remove is referenced by other classes in the same model.
in fact Command cmd= RemoveCommand.create(ed, gn); is the same than
Command cmd = new RemoveCommand(ed,gn.eContainer(),GGraphPackage.eINSTANCE.getGIMPLE_Graph_Nodes(),gn);
it removes only references betwwen the element and its container but did not check other references!!!!
when I removed manually the other references of the element to remove, The exception disappear and I can save my model.
I am wondering what is the role of the ItemProvider, the AdapterFactory, and other classes generated by EMF if we should remove manually all the references of the element to remove.
I think that I miss some thing. any idea ? should I call explicitly the adapters, notifychange,etc ?
thank you very much.
Asma
Re: [EMF.Edit] removeCommand [message #675495 is a reply to message #675479] |
Tue, 31 May 2011 16:40 |
Ed Merks Messages: 33145 Registered: July 2009 |
Asma,
It sounds like you want the effect of a DeleteCommand, which cleans up
all references using RemoveCommand and SetCommand, depending on
multiplicity.
charfi asma wrote:
> Hello,
> by other classes in the same model. in fact Command cmd=
> Command cmd = new
> Asma
Ed Merks
FUDForum. Page generated in 0.04112 seconds
