problem between rcp applications [message #675269] |
Tue, 31 May 2011 01:16 |
hzmartin Messages: 1 Registered: August 2010 |
Junior Member |
I have one problem between rcp applications.
there's one rcp application named differencing, like beyond compare, a little bit.
first, I open the application, for example, executale file name is 'diff.exe'
by default, it's used to compare to two folders. below is the sample interface
|a.txt | a.txt |
|b.txt | b.txt |
then, I click on the first row which contains 'a.txt', the application will invoke 'diff.exe' by ProcessBuilder#start recursively. and it will compare the two 'a.txt' files.
but GUI interface of the second 'diff.exe' will not appear until the first one closed, it seems there's resource lock.
after I remove one java statement which is executed in the startup,
'java.util.logging.Logger.log(Level.ERROR, "...")', the application works fine.
I don't know why the logging statement will cause the problem.
Does anyone know what's wrong with my application?
Thank you
Martin
[Updated on: Tue, 31 May 2011 01:20] Report message to a moderator
FUDForum. Page generated in 0.05726 seconds
