| Home » Eclipse Projects » Babel » Fw: uomo in structural engineering project(forwarding discussion on missing message bundles with Babel)
 Goto Forum:|
|  Fw: uomo in structural engineering project [message #674911] | Sun, 29 May 2011 08:46 |  |
| Eclipse User  |  |  |  |  | Dear Kit/all,
 Could you please help the import the UOMo message bundles into Babel?
 The download site is now http://download.eclipse.org/uomo/rc2/ or (should the RC be a problem
  also on the preview to 0.6 http://download.eclipse.org/uomo
 Luca and other Eclipse community members would be more than happy to contribute to translations or symbols still missing for certain countries and locales.
 Werner
 ----- Original Message -----
 Newsgroups: eclipse.uomo
 Sent: Friday, May 27, 2011 3:57 AM
 Subject: Re: uomo in structural engineering project
 > Dear Werner,
 > I try and keep the discussion alive (see previous post in this tread,
 > also quoted below):
 > - I have noticed that some non-SI units (both in NonSI and in
 > USCustomary) lack of symbol in messages.properties (e.g., inch, pound,
 > pound-force, metric-ton), some other unit symbols in the same file have
 > been commented. I do not see the reason (I had to add the first group
 > and uncomment the second group for my test to work.
 > - How does UOMo relate to JScience? You mentioned J.M. Dautelle, who
 > seems now active in JScience. Are the two projects still connected
 > somehow (besides using the same API)?
 > Best wishes,
 > Luca
 > Dear Werner,
 > thanks for you reply.
 > On 16/05/2011 00:01, Werner Keil wrote:
 >> Dear Luca,
 >> Thanks a lot for raising the question and exploration use
 >> cases for UOMo in your structural engineering project.
 >> The org.eclipse.uomo.units.NonSI class was taken from the
 >> earlier (JSR) implementation, Jean-Marie, myself and others
 >> had worked on.
 >> It was pointed out by people at Google and others providing
 >> input, that this SystemOfUnits may not have the most lucky
 >> name, and seem a bit like "dump" for all kinds of units
 >> that don't fit into other categories.
 > I provide some more details on what I am doing, hoping that the
 > description of an usage-attempt be useful.
 > While exploring uomo, I needed some units already defined in NonSI (e.g.
 > kilogram-force). Then I tried adding new units useful for my project.
 > Indeed, I started treating NonSI exactly as you wrote: I put all new
 > units in it (and upgraded the class and its constants to public, for the
 > sake of my tests).
 > Units I had to add for my structural engineering project are those still
 > used by some practitioner engineers, for example, the metric-tonn-force,
 > or the metric-technical-unit-of-mass (the mass which accelerated by 1
 > m/s results in 1 kgf). I think that these units might be common also in
 > other European countries besides Italy and deserve to be added somewhere
 > instead than being redefined by users (such as me).
 > Whether these units belong to a clearly nameable set, I am not sure. If
 > it were for Italy, I would put them in an EngineeringCustomary or
 > something similar. On the other hand, they may be happy to stay in
 > NonSI, with their friends kilogram-force, etc.
 > I agree that NonSI is quite vague and wide. Maybe some units should be
 > moved to an UK specific set, and other to a "SIAffine" set, in which I
 > would put units which are non-SI but whose definition is dependent on SI
 > (e.g. kilogram-force, metric ton, angstrom, and those that I defined above).
 > BTW, I also added some units, which, I assumed, are common in US
 > engineering practice, such as kilopound (kip) and kilopound-force
 > (kipf). The assumption is due to the fact that they are present in every
 > US engineering program I checked. These units might be at home in
 > USCustomary, but I am not in the (geographic) position to assert that.
 >> Thus USCustomary was
 >> created which you may notice, contains certain units for
 >> the US context, which NonSI has similar UK counterparts
 >> for. I'm open to constructive suggestions for a new Out of The
 >> Box system similar to SI or USCustomary. Considering it is
 >> final at the moment like all other unit systems, I agree,
 >> its members are pretty much for internal usage only.
 >> An alternative to creating further (final) default unit
 >> systems would be to move the elements into
 >> org.eclipse.uomo.units.AbstractSystemOfUnits making them
 >> abstract and thus only available for implementing unit
 >> systems.
 > This sound interesting too. However, my first temptation when seeing a
 > class named AbstractSystemOfUnits would be to derive from it (as it is
 > currently done in uomo). This would end-up in having all units available
 > in concrete sub-classes and this might create some confusion.
 >> This would also allow usage by custom-specific unit systems,
 >> i.E. if you find such need in your project or other use
 >> cases.
 >> Kind Regards,
 >> Werner
 > Kind regards,
 > Luca
 [Updated on: Mon, 30 May 2011 09:10] by Moderator |  |  |  |
 Current Time: Fri Oct 31 04:16:13 EDT 2025
 Powered by FUDForum . Page generated in 0.03749 seconds |
