Home » Archived » SeMantic Information Logistics Architecture (SMILA) » SMILA Plug-In Development and Maven
SMILA Plug-In Development and Maven [message #674527] Fri, 27 May 2011 05:19 Go to next message
Is there a standard way to integrate SMILA Plug-In development (as described here wiki.eclipse.org/SMILA/Development_Guidelines/Create_a_bundle_%28plug-in%29) with Maven?
I found a way to generate the MANIFEST.MF which includes the Maven-Dependencies and it works, but its more a workaround...
Has anyone ever done Plug-In Development with Maven?
Re: SMILA Plug-In Development and Maven [message #674568 is a reply to message #674527] Fri, 27 May 2011 06:32 Go to previous messageGo to next message
Originally posted by:
Am 27.05.2011, 11:19 Uhr, schrieb Christoph Diefenthal
<forums-noreply@eclipse.org>:
No, sorry, we did not use Maven with SMILA yet.
But if you manage to make it work, it would be great if you could add a
how-to
description to the SMILA wiki (-:
Jürgen.
Re: SMILA Plug-In Development and Maven [message #675056 is a reply to message #674527] Mon, 30 May 2011 03:34 Go to previous messageGo to next message
hi,
are u talking about normal/vanilla maven or the tycho build?
we have tried the latter *a little bit* but gave up on it as it involved
too many changes in smila and some things we couldnt get to work --
which might, in all likelihood, was due to the fact of limited
understanding/knowledge of tycho and resources willing to commit to the
area.
> described here
> with Maven?
thomas menzel aka tom
Re: SMILA Plug-In Development and Maven [message #677826 is a reply to message #675056] Thu, 09 June 2011 10:03 Go to previous messageGo to next message
Hi there,
as Tom stated, working with Maven and Equinox is pain in the ass. We hooked our libraries in via svn externals - a bit tricky, but if one is aware of that it works like charm.
Another way of handling dependencies is Buckminster. Here you can use repositories of various different technologies to get your dependencies (M2 and Ivy repos for example).
Give it a try Wink
Re: SMILA Plug-In Development and Maven [message #678800 is a reply to message #677826] Thu, 09 June 2011 10:37 Go to previous messageGo to next message
Hi Martin,
Could you please provide us some details (or even better create a Wiki
page under http://wiki.eclipse.org/SMILA/HowTo) so that we and the rest
of the community can profit from it?
Cheers
Igor
Re: SMILA Plug-In Development and Maven [message #781056 is a reply to message #678800] Fri, 20 January 2012 04:18 Go to previous messageGo to next message
Hi@all,
my last post is quite a while old - and a lot of things have changed. I moved to a new project/employer and am now in the lucky position to work with Eclipse/OSGI again.
One of my first task was to provide a headless build environment for the project we are working on here. I tried PDE Headless and also gave Buckminster a glimpse - until I stumbled over Eclipse Tycho (http://www.eclipse.org/tycho/) again.
This project provides Maven plugins for OSGI/RCP specific tasks - and it's very easy to use. The project structure stays the same, dependencies are gathered from MANIFEST.MF and plugin.xml
All you need is a parent project that bequests the settings to the child projects/modules. "Tripping hazard": The artifact-id and plugin-id, maven-version and plugin-version have to be the same. Thats all. It has cost me half a day to convert all fragments to maven projects and now it works like charm Smile
parent-project pom:
<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
	xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
	<modelVersion>4.0.0</modelVersion>
	<groupId>your.group.id</groupId>
	<artifactId>your-artifact-name</artifactId>
	<version>1.0-SNAPSHOT</version>
	<packaging>pom</packaging>
	<name>ProBaTe Parent Project</name>
	<!-- tycho requires maven >= 3.0 -->
	<prerequisites>
		<maven>3.0</maven>
	</prerequisites>
	<properties>
		<tycho-version>0.13.0</tycho-version>
	</properties>
	<repositories>
		<!-- configure p2 repository to resolve against -->
		<repository>
			<id>indigo</id>
			<layout>p2</layout>
			<url>http://download.eclipse.org/releases/indigo</url>
			<!-- file URL for faster and offline builds -->
			<!-- <url>file:/${basedir}/../../helios-rcp/</url> -->
		</repository>
		<!-- SWTbot is not part of the helios update site -->
		<repository>
			<id>swtbot</id>
			<layout>p2</layout>
			<url>http://download.eclipse.org/technology/swtbot/helios/dev-build/update-site/</url>
		</repository>
	</repositories>
	<build>
		<plugins>
			<plugin>
				<!-- enable tycho build extension -->
				<groupId>org.eclipse.tycho</groupId>
				<artifactId>tycho-maven-plugin</artifactId>
				<version>${tycho-version}</version>
				<extensions>true</extensions>
			</plugin>
			<plugin>
				<artifactId>target-platform-configuration</artifactId>
				<configuration>
					<!-- configure the p2 target environments for multi-platform build -->
					<environments>
						<environment>
							<os>linux</os>
							<ws>gtk</ws>
							<arch>x86_64</arch>
						</environment>
						<environment>
							<os>win32</os>
							<ws>win32</ws>
							<arch>x86_64</arch>
						</environment>
					</environments>
				</configuration>
			</plugin>
			<!-- enable source bundle generation -->
			<plugin>
				<artifactId>tycho-source-plugin</artifactId>
				<executions>
					<execution>
						<id>plugin-source</id>
						<goals>
							<goal>plugin-source</goal>
						</goals>
					</execution>
				</executions>
			</plugin>
		</plugins>
	</build>
</project>
A pom for a eclipse-plugin (and there are even more packaging options, have a look onto https://github.com/jsievers/tycho-demo)
	<artifactId>TestplanGenerationPlugin</artifactId>
	<version>1.0.5</version>
	<packaging>eclipse-plugin</packaging>
	<parent>
		<groupId>org.infai.probate</groupId>
		<artifactId>probate-parent</artifactId>
		<relativePath>../probate-parent/pom.xml</relativePath>
	</parent>
</project>
Have fun,
Martin
Re: SMILA Plug-In Development and Maven [message #782327 is a reply to message #781056] Mon, 23 January 2012 09:39 Go to previous messageGo to next message
Thank you Martin for sharing your experience with us!
Is there any chance that you write this down on a Wiki-Page (e.g.
http://wiki.eclipse.org/SMILA/HowTo/Maven_Build) and post a link in user
and/or dev mailing list so that also the rest of the community can
profit from it?
Cheers
Igor
Am 20.01.2012 10:18, schrieb Martin Röbert:
> Hi@all,
> works like charm :)
> parent-project pom:
> <prerequisites>
> <maven>3.0</maven>
> </prerequisites>
> <properties>
> </properties>
> <repositories>
> <repository>
> <id>indigo</id>
> <layout>p2</layout>
> </repository>
> <repository>
> <id>swtbot</id>
> <layout>p2</layout>
> </repository>
> </repositories>
> <build>
> <plugins>
> <plugin>
> </plugin>
> <plugin>
> <configuration>
> <environments>
> <environment>
> <os>linux</os>
> <ws>gtk</ws>
> <arch>x86_64</arch>
> </environment>
> <environment>
> <os>win32</os>
> <ws>win32</ws>
> <arch>x86_64</arch>
> </environment>
> </environments>
> </configuration>
> </plugin>
> <plugin>
> <executions>
> <execution>
> <goals>
> </goals>
> </execution>
> </executions>
> </plugin>
> </plugins>
> </build>
> </project>
> <parent>
> </parent>
> </project>
> Have fun,
> Martin
Re: SMILA Plug-In Development and Maven [message #789851 is a reply to message #674527] Fri, 03 February 2012 08:48 Go to previous message
I'll do my very best.
When I am finished writing that part of the documentation in our wiki, I'll contribute it Smile
Previous Topic:SMILA 1.0 released!
Next Topic:Would be SMILA useful in this context?
Current Time: Fri Nov 07 11:26:22 EST 2025
Powered by FUDForum. Page generated in 0.05968 seconds
