| MWE2 workflow can't find MANIFEST.MF [message #673834] |
Tue, 24 May 2011 17:45  |
I have created a XText Project as per the user guide, added my .xtext grammar file. Right clicked on the mwe2 file and run as -> MWE2 WorkFlow. It always fails to find the MANIFEST.MF file (See the output below). I work around this by manually copying the MANIFEST.MF file to the correct location. But I am curious why this happens? I would like to understand what I am doing wrong. I have tried this numerous times both on 1.0.0 of XText and 1.0.2 with the same result. Can anybody provide some insight?
0 [main] INFO lipse.emf.mwe.utils.StandaloneSetup - Registering platform uri 'C:\Work\OccultMongoose'
858 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning C:\Work\OccultMongoose\eclipse_plugin\..\postilion.testharness.editor.eclipse.testharness\src-gen
868 [main] INFO ipse.emf.mwe.utils.DirectoryCleaner - Cleaning C:\Work\OccultMongoose\eclipse_plugin\..\postilion.testharness.editor.eclipse.testharness.ui\src-gen
1040 [main] INFO ipse.xtext.generator.LanguageConfig - generating infrastructure for postilion.testharness.editor.eclipse.TestHarness with fragments : ImplicitRuntimeFragment, ImplicitUiFragment, GrammarAccessFragment, EcoreGeneratorFragment, ParseTreeConstructorFragment, ResourceFactoryFragment, XtextAntlrGeneratorFragment, JavaValidatorFragment, ImportNamespacesScopingFragment, QualifiedNamesFragment, BuilderIntegrationFragment, FormatterFragment, LabelProviderFragment, TransformerFragment, OutlineNodeAdapterFactoryFragment, QuickOutlineFragment, QuickfixProviderFragment, JavaBasedContentAssistFragment, XtextAntlrUiGeneratorFragment
14940 [main] INFO or.validation.JavaValidatorFragment - executing generate for org.eclipse.xtext.generator.validation.JavaValidatorFragment
17944 [main] ERROR g.eclipse.xtext.generator.Generator - java.io.FileNotFoundException: ..\postilion.testharness.editor.eclipse.testharness\META-INF\MANIFEST.MF (The system cannot find the path specified)
org.eclipse.emf.common.util.WrappedException: java.io.FileNotFoundException: ..\postilion.testharness.editor.eclipse.testharness\META-INF\MANIFEST.MF (The system cannot find the path specified)
at org.eclipse.xtext.generator.Generator.mergeManifest(Generator.java:353)
at org.eclipse.xtext.generator.Generator.generateManifestRt(Generator.java:320)
at org.eclipse.xtext.generator.Generator.invokeInternal(Generator.java:115)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:126)
at org.eclipse.emf.mwe.core.lib.Mwe2Bridge.invoke(Mwe2Bridge.java:34)
at org.eclipse.emf.mwe.core.lib.AbstractWorkflowComponent.invoke(AbstractWorkflowComponent.java:201)
at org.eclipse.emf.mwe2.runtime.workflow.AbstractCompositeWorkflowComponent.invoke(AbstractCompositeWorkflowComponent.java:31)
at org.eclipse.emf.mwe2.runtime.workflow.Workflow.run(Workflow.java:19)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:80)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Runner.run(Mwe2Runner.java:52)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.run(Mwe2Launcher.java:74)
at org.eclipse.emf.mwe2.launch.runtime.Mwe2Launcher.main(Mwe2Launcher.java:35)
Caused by: java.io.FileNotFoundException: ..\postilion.testharness.editor.eclipse.testharness\META-INF\MANIFEST.MF (The system cannot find the path specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(FileInputStream.java:106)
at org.eclipse.xtext.generator.Generator.mergeManifest(Generator.java:339)
... 11 more
17945 [main] INFO .emf.mwe2.runtime.workflow.Workflow - Done.
Otto
FUDForum. Page generated in 0.02383 seconds
