Home » Modeling » TMF (Xtext) » How to implement function calls
How to implement function calls [message #673242] Sun, 22 May 2011 21:15 Go to next message
Hi!
I would like to have a language that supports something like:
MyDataType myVariable
myVariable.function()
This "function()" depends on the type of myVariable. In this example myVariable is of MyDataType type.
I don't have a deep knowledge of Xtext.
What way would you guys recommend me to implement this?
Re: How to implement function calls [message #673251 is a reply to message #673242] Sun, 22 May 2011 22:47 Go to previous messageGo to next message
Write the grammar for your language.
Write a compiler (generate code for an existing language such as Java) or an interpreter (evaluate/execute EMF model directly); in both cases you will be working with the EMF model created by Xtext from parsing code written in your language.
Re: How to implement function calls [message #673324 is a reply to message #673242] Mon, 23 May 2011 05:06 Go to previous messageGo to next message
Do you mean "support" syntactically?
Then I think that you have to write a dot notation in your grammar and customize eventually the scope provider.
In the forum there are old posts for the dot notation like here or here.
[Updated on: Mon, 23 May 2011 05:07] by Moderator
Re: How to implement function calls [message #673343 is a reply to message #673242] Mon, 23 May 2011 05:51 Go to previous messageGo to next message
this is something that is excessively used in Xtend2. So you might want to have a look at its grammar and infrastructure (I guess that will be a bit overwhelming, though).
Another recent post dealing with this question is this one. The grammar and scoping samples may give you an idea how to start.
Alex
Re: How to implement function calls [message #674097 is a reply to message #673343] Wed, 25 May 2011 16:03 Go to previous message
Thank you all for your help.
I would like to have a look to complex grammars to learn more. Where I can download the Xtent2 source code? or maybe another grammar I can have a look at?
Thank you!
Previous Topic:Syntax Graph formatting
Next Topic:Using templates
Current Time: Fri Nov 07 18:53:52 EST 2025
Powered by FUDForum. Page generated in 0.04123 seconds
