Re: Failed to Load JavaHL Library [message #673279 is a reply to message #673257] |
Mon, 23 May 2011 05:30 |
thoufiq Messages: 16 Registered: May 2011 |
Hi Nicole,
I had re-installed eclipse in my ubuntu server 10.10 and it is working fine but while trying to install eclipse subversion, i got a error that can't complete the install.
I clicked the menu HELP > Install new software and added the link Subclipse_1.6.x - http://subclipse.tigris.org/update_1.6.x then i got core SVNkit library, Optional JNA library and subclipse to install, then i marked all the three items and proceed to NEXT, after that it shows error like this.....
Quote:Cannot complete the install because one or more required items could not be found.
Software being installed: Subclipse Integration for Mylyn 3.x (Optional) 3.0.0 (org.tigris.subversion.subclipse.mylyn.feature.gro up 3.0.0)
Missing requirement: Subclipse Integration for Mylyn 3.x (Optional) 3.0.0 (org.tigris.subversion.subclipse.mylyn.feature.gro up 3.0.0) requires 'org.eclipse.mylyn.tasks.core [3.0.0,4.0.0)' but it could not be found
Help me to fix this issue
[Updated on: Mon, 23 May 2011 05:34] Report message to a moderator
Re: Failed to Load JavaHL Library [message #673544 is a reply to message #673460] |
Tue, 24 May 2011 04:39 |
Hello Eric,
I un-marked the Mylyn and installed other components but after installing subversion, svn perspective is not present in the WINDOW > Show view > other and also in WINDOW > Open perspective > other. I think plugins are not installed but i dont know the actual cause for this issue.
Can you suggest me to fix this issue.
[Updated on: Tue, 24 May 2011 08:49] Report message to a moderator
Re: Failed to Load JavaHL Library [message #675207 is a reply to message #675026] |
Mon, 30 May 2011 15:05 |
On 2011.05.29 23:11, thoufiq wrote:
> Hello all,
> I am waiting for the reply for my post named FAILED TO LOAD JAVAHL from
> 25th may 2011 but no one is replied to me. I don't know why the peoples
> are not responding to my post.
> Pls pls pls...any one help me to overcome this issue.
Thoufiq,
Think about how this forum works: unpaid folk answering questions when
a) they happen to know and b) they happen to get to the forum. I get to
this forum a couple of times per day. I just don't happen to know the
answer to your specific question.
Bumping the forum will never produce an answer faster, but, get this: it
may result in someone ignoring you who otherwise may have been happy to
answer.
Nevertheless, ...
I have written up my own experiences installing and using Subversion
with Eclipse. You're welcome to peruse my page, which you would have
found had you Googled a little more, if it can help at all:
http://www.javahotchocolate.com/tutorials/subclipse.html
FUDForum. Page generated in 0.09275 seconds
