Re: C++ Code Generation With Papyrus [message #765201 is a reply to message #672519] |
Tue, 13 December 2011 15:58 |
We (CEA LIST) ported the jet based C++ generator that was available as extension for Papyrus 1.12.x to the new version of Payprus. This generator is currently used within a different project (eC3M) and will propably be available in Spring 2012.
Re: C++ Code Generation With Papyrus [message #775667 is a reply to message #765201] |
Fri, 06 January 2012 13:46 |
I'm not sure, if I got your last message right: "The standalone version does not have C++ codegen. I downloaded eclipse galileo and papyrus."
Does it mean, you're now using the Papyrus 0.7.x/0.8.x from eclipse.org or still the older Papyrus 1.12?
In case of the latter, you can install the code generation add-in using the update-site
www.papyrusuml.org/home/liblocal/docs/updates/papyrus-extensions
FUDForum. Page generated in 0.03250 seconds
