Home » Modeling » GMF (Graphical Modeling Framework) » Delete Element - also delete Table in MySQL
Delete Element - also delete Table in MySQL [message #671965] Thu, 19 May 2011 09:28 Go to next message
Hi there,
my elemetents represent tables in a MySQL-database. So when I delete an element (via [DEL] or Menu->Delete From Model) the tabel should also be dropped in the databse. So that the table also is dropped is working. But I wrote the code in the DeleteElementAction in the package diagram.part. But now the table is always dropped when I select the node. So where do I have to write the code, that it is only deleted when it's supposed to?
Thanks in advance.
Re: Delete Element - also delete Table in MySQL [message #672187 is a reply to message #671965] Fri, 20 May 2011 05:04 Go to previous messageGo to next message
you can add an Command which extends an AbstractTransactionalCommand in XXXItemSemanticEditPolicy
for example AfterElementDeleteCommand extends AbstractTransactionalCommand {
	protected CommandResult doExecuteWithResult(IProgressMonitor monitor,
			IAdaptable info) throws ExecutionException {
                  //add here your mysql code
and then add this command to
protected Command getDestroyElementCommand(DestroyElementRequest req) {
		View view = (View) getHost().getModel();
		CompositeTransactionalCommand cmd = new CompositeTransactionalCommand(
				getEditingDomain(), null);
		cmd.setTransactionNestingEnabled(false);
cmd.add(new AfterElementDeleteCommand(getEditingDomain(), "delte", null, (IGraphicalEditPart) getHost()));
[Updated on: Fri, 20 May 2011 05:06] by Moderator
Re: Delete Element - also delete Table in MySQL [message #673682 is a reply to message #672187] Tue, 24 May 2011 09:11 Go to previous message
Thanks for your reply. But that leads me to another question. How do I pass the editPart throught the XXXSemanticEditPolicy to my XXXDeleteCommand?
Thanks in advance.
Previous Topic:Redundant space in compartments
Next Topic:(no subject)
Current Time: Sat Oct 25 05:17:12 EDT 2025
Powered by FUDForum. Page generated in 0.04704 seconds
