| AxisFaultException : No endpoint [message #671899] |
Thu, 19 May 2011 06:00  |
Eclipse User  |
I am using Exlipse to create web service and webservice client.
When I try to access the method of client I am getting the AxesFault Exception : No endpoint
Below is the error:
May 19, 2011 2:12:57 PM org.apache.axis.utils.JavaUtils isAttachmentSupported
WARNING: Unable to find required classes (javax.activation.DataHandler and javax.mail.internet.MimeMultipart). Attachment support is disabled.
AxisFault
 faultCode: {ABC:  xml.apache.org  / axis   }Server.NoEndpoint
 faultSubcode:
 faultString: No endpoint
 faultActor:
 faultNode:
 faultDetail:
	{ABC: // xml.apache.org  axis / }exceptionName:org.apache.axis.NoEndPointException
	{ABC: //  xml.apache.org  axis }stackTrace:No endpoint
	at com.ws3webservices.MyServiceSoap11BindingStub.deleteAccount(MyServiceSoap11BindingStub.java:238)
	at com.ws3webservices.TestClietn.main(TestClietn.java:11)
	{ABC:  xml.apache.org  axis  }hostname:ABC
No endpoint
I have removed the http from the above code because I am not allowed by the forum to use urls in the post.
Here is the code I am using in client
	WS3WebServiceSoap11BindingStub stub = new WS3WebServiceSoap11BindingStub();
	stub.deleteAccount(35);
How can i solve this?
FUDForum. Page generated in 0.09210 seconds
