Re: how to use the validate event of parameter [message #670077 is a reply to message #669930] |
Thu, 12 May 2011 15:02 |
Currently in BIRT the validate function throws an error if the function
returns a false statement:
if( paramval == notwhatitshouldbe ){
false;
}else{
true;
Generally the error is not very useful so you may just want to set a
variable in the validate parameter and use it in the report to forward.
Take a look at the attached report for an example.
Jason
<report xmlns="http://www.eclipse.org/birt/2005/design" version="3.2.22"
id="1">
<property name="createdBy">Eclipse BIRT Designer Version
2.6.1.v20100902 Build <2.6.1.v20100915-1750></property>
<property name="units">in</property>
<property name="iconFile">/templates/blank_report.gif</property>
<property name="bidiLayoutOrientation">ltr</property>
<property name="imageDPI">96</property>
<parameters>
<scalar-parameter name="myparm" id="7">
<method
name="validate"><![CDATA[//importPackage(Packages.javax.servlet);
//does not work
if( params["myparm"].value == "forward" ){
//reportContext.getHttpServletRequest().getRequestDispatcher ( "error/parmerror.jsp").forward(
reportContext.getHttpServletRequest(), null);
reportContext.setGlobalVariable("forw", true);
true;
}else{
reportContext.setGlobalVariable("forw", false);
true;
]]></method>
<property name="valueType">static</property>
<property name="dataType">string</property>
<property name="distinct">true</property>
<property name="paramType">simple</property>
<property name="controlType">text-box</property>
<structure name="format">
<property name="category">Unformatted</property>
</structure>
</scalar-parameter>
</parameters>
<styles>
<style name="report" id="4">
<property name="fontFamily">sans-serif</property>
<property name="fontSize">10pt</property>
</style>
<style name="crosstab-cell" id="5">
<property name="borderBottomColor">#CCCCCC</property>
<property name="borderBottomStyle">solid</property>
<property name="borderBottomWidth">1pt</property>
<property name="borderLeftColor">#CCCCCC</property>
<property name="borderLeftStyle">solid</property>
<property name="borderLeftWidth">1pt</property>
<property name="borderRightColor">#CCCCCC</property>
<property name="borderRightStyle">solid</property>
<property name="borderRightWidth">1pt</property>
<property name="borderTopColor">#CCCCCC</property>
<property name="borderTopStyle">solid</property>
<property name="borderTopWidth">1pt</property>
</style>
<style name="crosstab" id="6">
</style>
</styles>
<page-setup>
<simple-master-page name="Simple MasterPage" id="2">
<page-footer>
<text id="3">
<property name="contentType">html</property>
<text-property
name="content"><![CDATA[<value-of>new Date()</value-of>]]></text-property>
</text>
</page-footer>
</simple-master-page>
</page-setup>
<body>
<text id="8">
<text-property name="content"><![CDATA[<script
type="text/javascript">
function forward() {
if( <VALUE-OF>reportContext.getGlobalVariable("forw");</VALUE-OF >){
var temp = new String(location.href);
//var detailReport =
" nameofreportcontainingerrormessageyouwanttodisplay.rptdesign ";
//var TargetURL = temp.replace(/forwarddetail.rptdesign/, detailReport);
//location.replace(TargetURL);
location.replace("http://www.google.com");
return false;
forward();
</script>]]></text-property>
</text>
</body>
</report>
On 5/12/2011 2:23 AM, forums-noreply@eclipse.org wrote:
> I want to validate the input date field is earlier than
> system date 12:00:00 am, I know there is a validate event
> for input parameter, but how to use this event? any
> example?
FUDForum. Page generated in 0.02791 seconds
