Home » Language IDEs » Java Development Tools (JDT) » .xml:1: error: Error parsing XML: no element found (no main.out.xml to delete)
.xml:1: error: Error parsing XML: no element found (no main.out.xml to delete) [message #669859] Wed, 11 May 2011 16:38
Hello!
I'm currently working on developing an Android application, and today I wanted to create a new form, so I created a new XML file in res\layout. After playing with this new form for awhile, I decided to start over, so I right clicked the XML file and deleted it. (I don't believe I ever tried to run the emulator, but I may have.)
Now when I try to create a new .xml, I get an error saying:
Error in an XML file: aborting build.
(skipping index file '..\workspace\MyProject\res\drawable\Thumbs.db')
..\workspace\MyProject\res\layout\tempxmlfile.xml:1: error: Error parsing XML: no element found
where tempxmlfile.xml is whatever I name the XML file.
As a clarification, I am not using caps in the file name, and there are no .out.xml files anywhere in the project to delete.
Does anyone have any ideas? I've tried cleaning, both before and after I add the XML files, to no avail. If I remove the XML files, there are no errors, but as soon as I add one back, they reappear immediately.
Thanks ahead of time for any help,
Sid
Previous Topic:Windows 7 Remote Java Application problem
Next Topic:Error highlight
Current Time: Thu Oct 30 16:02:30 EDT 2025
Powered by FUDForum. Page generated in 0.06399 seconds
