Dynamic branchToTag in cquery [message #669229] |
Mon, 09 May 2011 14:25 |
Originally posted by: Holger Schmid
our development strategy uses svn with a lot of branching. All branches
shall be build and tested on a CI-Server (e.g. Jenkins).
To build our application, we are using the following build.cquery with
one advisor node:
---- build.cquery ----
<cq:componentQuery ... resourceMap="build.rmap">
<cq:rootRequest name="..." componentType="eclipse.feature" />
<cq:advisorNode namePattern="^my.plugin(\..+)?"
useTargetPlatform="false" branchTag="myBranch" />
</cq:componentQuery>
The build.rmap looks has a svn provider:
---- build.rmap ----
<rmap>
<searchPath name="svn">
<uri
format=" http://user:passwd@svnServer/trunk/{0}?moduleAfterTag&am p;moduleAfterBranch">
<bc:propertyRef key="buckminster.component" />
</uri>
</searchPath>
<locator ... />
</rmap>
This works fine as long as the value for branchTag in the cquery is
hard-coded.
Now the problem:
as we do have a lot of branches, we would like to use the same cquery
for all of our branches in order to get our product built and tested on
the CI-Server. What we would like to do is to set the value of the
branchTag using properties when calling the import for our headless
buckminster build:
e.g. change the branchTag in the cquery to:
<cq:advisorNode ... branchTag="${branch}" />
Invoke the import for the headless build on Jenkins:
import -D branch=myBranch $WORKSPACE/build.cquery
Unfortuantly, this however does not work - we are receiving the
following errors during materialization:
my.feature: branch myBranch rejected: not in '${branch}'
my.feature: branch someOtherBranch rejected: not in '${branch}'
It looks like ${branch} has not been correctly replaced by "myBranch".
Do you have any solution to get this running?
Holger
Re: Dynamic branchToTag in cquery [message #669374 is a reply to message #669344] |
Tue, 10 May 2011 06:21 |
Hello Henrik,
thanks for your response.
Do you have an idea how to put this variability into the rmap. I was
thinking about setting up the uri for the svn provider but this is quite
limited as the resolve mechanism for the svn provider expects "trunk" in
the uri-template and then determines the correct uri of using the
branchToTag value from the cquery. But mayby thats's the wrong way...
Holger
Am 10.05.2011 03:20, schrieb Henrik Lindberg:
> Did you consider putting the variability into the rmap instead?
> I think you can do a lot more with variables there.
> - henrik
> On 5/9/11 4:25 PM, Holger Schmid wrote:
>> Hello,
>> one advisor node:
>> <rmap>
>> <uri
>> </uri>
>> </searchPath>
>> <locator ... />
>> </rmap>
>> hard-coded.
>> Now the problem:
>> buckminster build:
>> Best regards,
>> Holger
FUDForum. Page generated in 0.03145 seconds
