Home » Eclipse Projects » EGit / JGit » Rebase with dirty working tree shouldn't execute.
Rebase with dirty working tree shouldn't execute. [message #668593] Fri, 06 May 2011 07:21 Go to next message
I found that in (native)git, when I try execute REBASE on dirty working tree, git stops with warning: "Working tree is dirty"
When I try this with Eclipse, there is no problem to EGit/JGit.
It is very dangerous when you try eg PULL (with rebase strategy).
When EGit hit in conflict, and you select "abort rebase", you lost all your uncommited changes.
"Rebase abort" is like reset hard.
I think rebase should check status before starts, and not execute if there are any uncommited changes.
Best regards
Pawel.
Re: Rebase with dirty working tree shouldn't execute. [message #673227 is a reply to message #668593] Sun, 22 May 2011 19:24 Go to previous messageGo to next message
That's bad, EGit should behave like native git here. Could you file a bug [1].
[1] https://bugs.eclipse.org/bugs/enter_bug.cgi?product=EGit
Re: Rebase with dirty working tree shouldn't execute. [message #676009 is a reply to message #668593] Thu, 02 June 2011 07:24 Go to previous message
I'm fairly sure that bug has been fixed in the current nightly builds.
Previous Topic:Status of working tree in Repository view
Next Topic:eGit push going to refs/for/master instead of refs/head/master?
Current Time: Fri Nov 07 06:13:28 EST 2025
Powered by FUDForum. Page generated in 0.04971 seconds
